Home » Polarsys » Capella workbench » Image as a Note(Can I add an image as a Note?)
Image as a Note [message #1833004] Wed, 30 September 2020 09:26 Go to next message
I would like to know if there is a way to add an image as a note to a diagram.
Is it possible? If so, how can I do it?
Re: Image as a Note [message #1833013 is a reply to message #1833004] Wed, 30 September 2020 11:13 Go to previous messageGo to next message
Hi Luc,
No, you can't add an image as a note to a diagram.
However, you can use images in the diagram description or customize elements' appearance using an image.
Re: Image as a Note [message #1833017 is a reply to message #1833013] Wed, 30 September 2020 12:36 Go to previous messageGo to next message
You may use a constraint to do it.
Re: Image as a Note [message #1833033 is a reply to message #1833017] Thu, 01 October 2020 03:25 Go to previous message
Ok, thank you very much for your replies
Previous Topic:Anomalies when using GIT-CAPELLA coupling (merge tool)
Next Topic:Search for diagams with broken elements
Current Time: Sun Aug 31 12:46:31 EDT 2025
Powered by FUDForum. Page generated in 0.04259 seconds
