Home » Eclipse Projects » Eclipse Platform » Selected string not delete while type new string.
Selected string not delete while type new string. [message #1832733] Wed, 23 September 2020 23:19 Go to next message
I'm not sure why I can't find the solution in whole internet, it should common problem.
I use the Eclipse for Java Editor, the version is
Version: 2020-09 (4.17.0)
Build id: 20200910-1200
When I like replace some string in the editor, I'll select the string that I want to been replace and type new string immediately, in older version Eclipse, the editor will delete the selected string then show the new string at the same place, but it become insert the new string front selected string, how can I change it to old style?
Re: Selected string not delete while type new string. [message #1832758 is a reply to message #1832733] Thu, 24 September 2020 10:02 Go to previous messageGo to next message
Sounds like a bug in Eclipse or a no longer supported platform. Which OS are you using? And if it is Linux, which GTK version are you using?
Re: Selected string not delete while type new string. [message #1832769 is a reply to message #1832758] Thu, 24 September 2020 12:00 Go to previous messageGo to next message
Might it be related to the "Smart Insert" versus Overwrite setting in the status bar area (or Smart Insert Mode on the Edit menu)?
Re: Selected string not delete while type new string. [message #1832840 is a reply to message #1832769] Sat, 26 September 2020 09:19 Go to previous messageGo to next message
thx for your reply, I tried, no matter"Smart Insert" or "Override"(the status show on the button of eclipse), it still not delete selected string, it override the text from first selected text, remain text still there while Override, is it only I encountered the situation on Win10?
[Updated on: Sat, 26 September 2020 11:13] by Moderator
Re: Selected string not delete while type new string. [message #1832841 is a reply to message #1832758] Sat, 26 September 2020 09:24 Go to previous messageGo to next message
thx for your reply, I use win10 and coding for Java, the situation happen on new version, the Oxygen version still fine.
Re: Selected string not delete while type new string. [message #1833044 is a reply to message #1832841] Thu, 01 October 2020 05:46 Go to previous message
Can anyone help?
Previous Topic:Eclipse 2200 v. 3.7.2 Host Manager Error - The Connection Already Exists
Next Topic:Eclipse IDE, project context menu - move the Close option far far away from Refresh
Current Time: Mon Nov 10 13:56:34 EST 2025
Powered by FUDForum. Page generated in 0.04387 seconds
