Home » Modeling » TMF (Xtext) » Problem with Maven-Tycho build of Xtext project in GitLab CI
Problem with Maven-Tycho build of Xtext project in GitLab CI [message #1832806] Fri, 25 September 2020 07:53 Go to next message
We are building an Eclipse Xtext based project with Maven and the Tycho plugin. Everything works fine, except for the automated tests in GitLab CI/CD. These fail because somehow the main class in the org.eclipse.equinox.launcher dependency cannot be found:
148908 [INFO] Command line:
[/usr/lib/jvm/java-11-openjdk-amd64/bin/java, -Dosgi.noShutdown=false, -Dosgi.os=linux, -Dosgi.ws=gtk, -Dosgi.arch=x86_64, , --add-modules=ALL-SYSTEM, -Dosgi.clean=true, -jar, /builds/qrml/qrml-dsl/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.launcher/1.5.700.v20200207-2156/org.eclipse.equinox.launcher-1.5.700.v20200207-2156.jar, -debug, -consolelog, -data, /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work/data, -install, /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work, -configuration, /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work/configuration, -application, org.eclipse.tycho.surefire.osgibooter.headlesstest, -testproperties, /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/surefire.properties]
Error: Could not find or load main class
Caused by: java.lang.ClassNotFoundException:
Locally (windows environment, Maven 3.6.3, JDK 13.0.1) this works fine: tests are executed normally as expected during the Maven build. I tried to add the org.eclipse.equinox.launcher explicitly (test scope) but that doesn't help. Juding from the log files, the jar is present. The CI environment is an Ubuntu server with openjdk 11.0.8 and Maven 3.6.0.
Any hints or pointers on how to solve this are greatly appreciated, thanks!
Martijn
Re: Problem with Maven-Tycho build of Xtext project in GitLab CI [message #1832808 is a reply to message #1832806] Fri, 25 September 2020 08:25 Go to previous messageGo to next message
hi,
do you have a complete stacktrace?
the "(test scope) " statement i dont understand. this is a tycho build, not a pure maven build correct?
do you have Xvnc/Xvfb etc running on Gitlab?
Re: Problem with Maven-Tycho build of Xtext project in GitLab CI [message #1832809 is a reply to message #1832808] Fri, 25 September 2020 08:32 Go to previous messageGo to next message
p.s: does a project create with the wizard work for you on your gitlab?
Re: Problem with Maven-Tycho build of Xtext project in GitLab CI [message #1832812 is a reply to message #1832809] Fri, 25 September 2020 09:06 Go to previous messageGo to next message
Here is more logging:
148979 [INFO] ------------------------------------------------------------------------
148979 [INFO] Reactor Summary for nl.tue.ele.es.qrml.parent 1.0.0-SNAPSHOT:
148979 [INFO]
148979 [INFO] nl.tue.ele.es.qrml.parent .......................... SUCCESS [  0.032 s]
148979 [INFO] nl.tue.ele.es.qrml ................................. SUCCESS [ 29.657 s]
148979 [INFO] nl.tue.ele.es.qrml.ide ............................. SUCCESS [  0.885 s]
148979 [INFO] nl.tue.ele.es.qrml.ui .............................. SUCCESS [  0.473 s]
148979 [INFO] nl.tue.ele.es.qrml.lsp ............................. SUCCESS [  4.333 s]
148979 [INFO] nl.tue.ele.es.qrml.gen ............................. SUCCESS [  4.231 s]
148979 [INFO] nl.tue.ele.es.qrml.target .......................... SUCCESS [  0.004 s]
148979 [INFO] nl.tue.ele.es.qrml.feature ......................... SUCCESS [  0.078 s]
148979 [INFO] nl.tue.ele.es.qrml.repository ...................... SUCCESS [  1.147 s]
148979 [INFO] nl.tue.ele.es.qrml.tests ........................... FAILURE [  1.214 s]
148979 [INFO] nl.tue.ele.es.qrml.ui.tests ........................ SKIPPED
148979 [INFO] BUILD FAILURE
148979 [INFO] Total time:  02:28 min
148979 [INFO] Finished at: 2020-09-25T09:12:10Z
148980 [ERROR] Failed to execute goal org.eclipse.tycho:tycho-surefire-plugin:1.7.0:test (default-test) on project nl.tue.ele.es.qrml.tests: An unexpected error occurred while launching the test runtime (process returned error code 1). Command-line used to launch the sub-process was null -Dosgi.noShutdown=false -Dosgi.os=linux -Dosgi.ws=gtk -Dosgi.arch=x86_64
148980 [ERROR]  --add-modules=ALL-SYSTEM
148980 [ERROR]  -Dosgi.clean=true -jar /builds/qrml/qrml-dsl/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.launcher/1.5.700.v20200207-2156/org.eclipse.equinox.launcher-1.5.700.v20200207-2156.jar -debug -consolelog -data /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work/data -install /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work -configuration /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work/configuration -application org.eclipse.tycho.surefire.osgibooter.headlesstest -testproperties /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/surefire.properties in working directory /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests
148980 [ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.eclipse.tycho:tycho-surefire-plugin:1.7.0:test (default-test) on project nl.tue.ele.es.qrml.tests: An unexpected error occurred while launching the test runtime (process returned error code 1). Command-line used to launch the sub-process was null -Dosgi.noShutdown=false -Dosgi.os=linux -Dosgi.ws=gtk -Dosgi.arch=x86_64
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:215)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:156)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:148)
    at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:117)
    at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:81)
    at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build (SingleThreadedBuilder.java:56)
    at org.apache.maven.lifecycle.internal.LifecycleStarter.execute (LifecycleStarter.java:128)
    at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:305)
    at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:192)
    at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:105)
    at org.apache.maven.cli.MavenCli.execute (MavenCli.java:956)
    at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:288)
    at org.apache.maven.cli.MavenCli.main (MavenCli.java:192)
    at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
    at jdk.internal.reflect.NativeMethodAccessorImpl.invoke (NativeMethodAccessorImpl.java:62)
    at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke (Method.java:566)
    at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:289)
    at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:229)
    at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:415)
    at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoFailureException: An unexpected error occurred while launching the test runtime (process returned error code 1). Command-line used to launch the sub-process was null -Dosgi.noShutdown=false -Dosgi.os=linux -Dosgi.ws=gtk -Dosgi.arch=x86_64
    at org.eclipse.tycho.surefire.TestMojo.runTest (TestMojo.java:1093)
    at org.eclipse.tycho.surefire.TestMojo.execute (TestMojo.java:712)
    at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo (DefaultBuildPluginManager.java:137)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:210)
148981 [ERROR]
148981 [ERROR]
148981 [ERROR] For more information about the errors and possible solutions, please read the following articles:
148981 [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
148981 [ERROR]
148981 [ERROR] After correcting the problems, you can resume the build with the command
148981 [ERROR]   mvn <goals> -rf :nl.tue.ele.es.qrml.tests
The "(test scope) " statement i dont understand. this is a tycho build, not a pure maven build correct?
Yes, it is a Tycho build. The project has been created from the Wizard and only slightly modified. I will check whether a "clean" wizard project works on our GitLab.
Re: Problem with Maven-Tycho build of Xtext project in GitLab CI [message #1832814 is a reply to message #1832812] Fri, 25 September 2020 09:16 Go to previous messageGo to next message
please also share your gitlab yml
Re: Problem with Maven-Tycho build of Xtext project in GitLab CI [message #1832816 is a reply to message #1832814] Fri, 25 September 2020 09:46 Go to previous messageGo to next message
A clean wizard project builds successfully after I configure <useUIHarness>false</useUIHarness> in the ui tests. (I have this configured to false also in the project that doesn't build).
The gitlab-ci.yml is the following:
before_script:
    - apt-get update
    - apt-get install -y default-jre default-jdk
    - apt-get install -y maven
build:
    variables:
    tags:
        - Ubuntu1804-64bit
    script:
        - mkdir /builds/qrml/qrml-dsl/testoutput
        - cd QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent
        - mvn -X verify 2>&1 | tee /builds/qrml/qrml-dsl/testoutput/Maven-debug-output.txt
    artifacts:
      expire_in: 14d
      when: always
      paths:
      - /builds/qrml/qrml-dsl/testoutput
This script worked for the Wizard project. The strange thing is that the main project started from the Wizard and I don't think I modified any pom.xml files except for the root pom to include two other modules and the ui.test pom to disable the UI harness.
Re: Problem with Maven-Tycho build of Xtext project in GitLab CI [message #1832819 is a reply to message #1832816] Fri, 25 September 2020 10:09 Go to previous messageGo to next message
why not use xnc or xvfb for ui tests
(latet tested this 2 years ago, might have changed: https://gitlab.com/cdietrich/my-xtext-p2-sample/-/blob/master/.gitlab-ci.yml)
Re: Problem with Maven-Tycho build of Xtext project in GitLab CI [message #1832864 is a reply to message #1832819] Mon, 28 September 2020 03:00 Go to previous message
Found the cause of the issue: Autoformatting applied to the parent pom.xml broke a line that should not be broken:
 <!-- THE FOLLOWING LINE MUST NOT BE BROKEN BY AUTOFORMATTING -->
<argLine>${platformSystemProperties} ${systemProperties} ${moduleProperties} ${additionalTestArguments}</argLine>
Apparently, breaking this line is no problem on Windows, but causes the "java.lang.ClassNotFoundException" on *nix.
Anyway, thanks for looking into this.
Previous Topic:Help with labeling features
Next Topic:Can I make Xtext throw, when a containment reference is reassigned?
Current Time: Wed Jul 23 11:55:09 EDT 2025
Powered by FUDForum. Page generated in 0.06171 seconds
