Home » Modeling » EMF » Updating ecore resource slows down build process
Updating ecore resource slows down build process [message #1832450] Fri, 18 September 2020 04:37 Go to next message
During each build process in Eclipse 4.16, the progress view stalls for minutes with the message 'Building myProject: Updating resource myModel.ecore', which sums up during an office day. That file is about 188kB large.
Is there anything I can do to accelerate the build process, e.g. preven that resource update unless it actually changed? (Is this the right forum?)
Thank you in advance.
Re: Updating ecore resource slows down build process [message #1832457 is a reply to message #1832450] Fri, 18 September 2020 06:20 Go to previous messageGo to next message
Does this project have an Xtext nature? I.e., this in the .project file:
<nature>org.eclipse.xtext.ui.shared.xtextNature</nature>
You can make .* files visible via the view menu's Filters... and uncheck the .* resources item.
Nothing in EMF itself does such building...
Re: Updating ecore resource slows down build process [message #1832459 is a reply to message #1832457] Fri, 18 September 2020 07:13 Go to previous messageGo to next message
Ed, thanks for the hint. Yes, it has Xtext nature, because we use an Xtext based DSL as a boiler plate code generator in the project. I'm checking what happens when it is disabled. Maybe I'll just have to move the Ecore file to a separate project without Xtext.
Re: Updating ecore resource slows down build process [message #1832463 is a reply to message #1832459] Fri, 18 September 2020 08:06 Go to previous messageGo to next message
That is a helpful workaround indeed: Keep Ecore files and 'actual' Xtext stuff in separate projects. Ecore code generation to the same project is no problem via the genmodel's settings.
[Updated on: Fri, 18 September 2020 08:07] by Moderator
Re: Updating ecore resource slows down build process [message #1832477 is a reply to message #1832463] Fri, 18 September 2020 10:00 Go to previous message
See https://www.eclipse.org/forums/index.php?t=msg&th=1105235&goto=1832475&#msg_1832475 on the Xtext forum for clearer guidance. The *.ecore can live with its built editor and NO Xtext nature, it is only the developer's build stuff that needs to be kept separate with an Xtext nature.
Ed Willink
Previous Topic:Downsides to bi-directional references?
Next Topic:Xcore editor not loaded anymore
Current Time: Thu Jul 24 02:43:02 EDT 2025
Powered by FUDForum. Page generated in 0.05193 seconds
