Home » Newcomers » Newcomers » Eclipse Mars crashes on startup(Eclipse crashing on startup)
Eclipse Mars crashes on startup [message #1832347] Wed, 16 September 2020 16:10 Go to next message
I have an embedded version of Eclipse Mars bundled with my Intel FPGA NIOS II tools.
When I try to start it I get an error message..
!SESSION 2020-09-16 15:38:27.224 -----------------------------------------------
eclipse.buildId=4.5.2.M20160212-1500
java.version=1.8.0_05
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.cpp.product -pluginCustomization C:/intelfpga_lite/18.1/nios2eds/bin/eclipse_nios2/plugin_customization.ini
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.cpp.product -pluginCustomization C:/intelfpga_lite/18.1/nios2eds/bin/eclipse_nios2/plugin_customization.ini
!ENTRY org.eclipse.osgi 4 0 2020-09-16 15:38:27.911
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could not be found in the registry. The applications available are: org.eclipse.cdt.codan.core.application, org.eclipse.cdt.core.GeneratePDOM, org.eclipse.cdt.managedbuilder.core.headlessbuild, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.equinox.app.error, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
I have uninstalling and reinstalling and I am still getting the same message.
Eclipse was starting yesterday.
in terms of Java I have
Java 8 Update 261 (64 bit)
Java SE Development Kit 8 Update 261 (64 bit)
I am running Windows 10 pro 64 bit.
  • Attachment: java.png
    (Size: 12.08KB, Downloaded 105 times)
Re: Eclipse Mars crashes on startup [message #1832356 is a reply to message #1832347] Thu, 17 September 2020 01:55 Go to previous messageGo to next message
Mars is super old and if someone else has repackaged it, then it's best to ask them. But given it's so old, it's likely that thing too super outdated as well...
Recent downloads are here:
Re: Eclipse Mars crashes on startup [message #1832402 is a reply to message #1832356] Thu, 17 September 2020 09:27 Go to previous messageGo to next message
It seems as if embedded providers who use Eclipse don't give us a choice as to Eclipse version.
I use Eclipse for two separate embedded devices: Netburner (NBEclipse) and Intel FPGA NIOS II.
On both platforms I have had bad experiences as they cannot answer questions like this. So I came here as a last resort,
I really wish they would not use Eclipse.
Re: Eclipse Mars crashes on startup [message #1832408 is a reply to message #1832402] Thu, 17 September 2020 09:33 Go to previous messageGo to next message
I really wish they would keep their distributions up-to-date.
Re: Eclipse Mars crashes on startup [message #1832466 is a reply to message #1832408] Fri, 18 September 2020 08:22 Go to previous messageGo to next message
Ed Merks wrote on Thu, 17 September 2020 13:33
I see how far they are out of date. Intel FPGA use Mars 2.0 for their 2020 release of of the NIOS II processor software.
To be frank I wish a lot of these embedded would stop using Eclipse and write their own IDE. Simply because they shrug responsibility when stuff goes wrong.
At least I got some honesty coming here.
Re: Eclipse Mars crashes on startup [message #1832498 is a reply to message #1832466] Sat, 19 September 2020 01:48 Go to previous messageGo to next message
Developing an IDE is far from a trivial exercise! Such a thing likely involves a great many millions of euros/dollars of investment. When we get things for free, wishes is all we get... I wish things that are tested with Java 8 just worked on Java 15 too, but alas, that's not the case either...
Re: Eclipse Mars crashes on startup [message #1832533 is a reply to message #1832498] Sun, 20 September 2020 13:32 Go to previous message
I also have this same problem is there anyone who can help me out of this .....?
[Updated on: Sun, 20 September 2020 15:41] by Moderator
Previous Topic:Update sites
Next Topic:cant upgrade from 4.14 to 4.15
Current Time: Mon Jul 28 10:32:58 EDT 2025
Powered by FUDForum. Page generated in 0.08434 seconds
