Home » Language IDEs » Java Development Tools (JDT) » MacOS Eclipse 2020-06 Java Debug Toolbar not showing
MacOS Eclipse 2020-06 Java Debug Toolbar not showing [message #1832100] Wed, 09 September 2020 01:01 Go to next message
[MacOS Catalina 10.15.6, Eclipse 2020-06 (PDT and Java)]
I'm running a Java Application in Debug mode, and when the application stops at my breakpoint, there is no toolbar to control the program flow.
I've tried a few options to get it back (because it does show while I'm debugging PHP code) but haven't had any luck.
What's going on?
[Updated on: Wed, 09 September 2020 01:01] by Moderator
Re: MacOS Eclipse 2020-06 Java Debug Toolbar not showing [message #1832121 is a reply to message #1832100] Wed, 09 September 2020 08:22 Go to previous messageGo to next message
Was Window->Perspective->"Reset Perspective" one of the options you've already tried?
[Updated on: Wed, 09 September 2020 08:24] by Moderator
Re: MacOS Eclipse 2020-06 Java Debug Toolbar not showing [message #1832141 is a reply to message #1832121] Thu, 10 September 2020 00:02 Go to previous messageGo to next message
I hadn't earlier, but it had no effect when I tried to do that.
Re: MacOS Eclipse 2020-06 Java Debug Toolbar not showing [message #1832578 is a reply to message #1832141] Mon, 21 September 2020 06:08 Go to previous message
Have you tried "Customize Perspective-> Debug" and then verify if Toolbar visibility has all the selections as you wish to have?
Previous Topic:org.eclipse.jdt.debug.ui v3.16 exception
Next Topic: Java developer tool
Current Time: Fri Nov 07 10:51:21 EST 2025
Powered by FUDForum. Page generated in 0.04432 seconds
