Home » Polarsys » Capella workbench » Anomalies when using GIT-CAPELLA coupling (merge tool)(When using GIT -CAPELLA coupling to solve a conflict with the merge tool two kinds of anomalies raise: not possible to launch merge tool or not possible to re-open .aird after conflict resolution)
Anomalies when using GIT-CAPELLA coupling (merge tool) [message #1831838] Mon, 31 August 2020 11:04 Go to next message
see details in the attached file
[Updated on: Mon, 31 August 2020 11:05] by Moderator
Re: Anomalies when using GIT-CAPELLA coupling (merge tool) [message #1831887 is a reply to message #1831838] Tue, 01 September 2020 16:20 Go to previous messageGo to next message
its seems there is a Sirius issue when using the merge tool while the aird session is opened.
If you close your aird (right click in it on Project Explorer > Close) before doing the Merge Tools it seems to work properly.
I will create a bugzilla to trace this issue. (https://bugs.eclipse.org/bugs/show_bug.cgi?id=566573)
[Updated on: Tue, 01 September 2020 16:23] by Moderator
Re: Anomalies when using GIT-CAPELLA coupling (merge tool) [message #1832184 is a reply to message #1831887] Fri, 11 September 2020 02:56 Go to previous message
Thanks for you answer, but
Closing the .aird before using merge tool (and also GIT merge and some GIT commands that modifies the eclipse files) is clearly mentionned in the Capella HELP contents, so I do it ... and I have the problems with merge tool that I mention in may post.
Previous Topic:PVMT property value and mass editing view
Next Topic:Image as a Note
Current Time: Mon Jul 21 02:39:44 EDT 2025
Powered by FUDForum. Page generated in 0.95458 seconds
