StackOverflowError in GEF 3.1M6 [message #181977] |
Fri, 20 May 2005 16:25  |
I am trying to run an Eclipse GEF-based plugin under Eclipse 3.1M6 with GEF
3.1M6.
For many but not all operations (dragging a node, drawing a specialized
anchor) I get a StackOverflowError.
The plugin did not have this problem with Eclipse 2.1, and I haven't tested
it with 3.0.
What is the cause of this problem?
Did something major change in GEF that I don't know about?
I tried to debug the problem, but didn't get anywhere.
Thanks, Felix
!ENTRY org.eclipse.ui 4 0 2005-05-16 15:59:30.769
!MESSAGE Failed to execute runnable (java.lang.StackOverflowError)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2860)
at org.eclipse.swt.SWT.error(SWT.java:2783)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:121)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2871)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2530)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Caused by: java.lang.StackOverflowError
Re: StackOverflowError in GEF 3.1M6 [message #182743 is a reply to message #182590] |
Thu, 26 May 2005 19:00   |
I found two ways to produce the exception:
1. When my diagram is drawn initially, a certain type of connection seems to
cause it. I removed all special drawing from that connection, it didn't make
a difference.
2. When I try to move a node in the diagram.
I don't think moving a node would be native DND, so the answer to your
question would be no.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:d730jm$875$1@news.eclipse.org...
> Is it possible that you are getting this exception during native DND? I
> think that SWT may post DND errors using an asyncexec, which is what your
> stack trace suggests.
> If this is the case, SWT should report more information. You could look
> for references to SWT.error within SWT's DropTarget class.
> "Felix L J Mayer" <felix.mayer@objectaid.com> wrote in message
> news:d6lh2q$kvj$1@news.eclipse.org...
>>GEF 3.1M6.
>> tested it with 3.0.
>> Thanks, Felix
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
FUDForum. Page generated in 0.06295 seconds
