Home » Modeling » QVT-OML » [QVTo] No constructor defined, using implicit constructor
[QVTo] No constructor defined, using implicit constructor [message #1831363] Tue, 18 August 2020 04:46 Go to next message
I am creating model elements in this way:
var myVar : Type = new Type();
And I'm getting the following warning: No constructor defined, using implicit constructor (equal to empty inline instantiation)
How would an "empty inline instantiation" look like?
If I just do
var myVar : Type;
it doesn't seem to work.
Re: [QVTo] No constructor defined, using implicit constructor [message #1831364 is a reply to message #1831363] Tue, 18 August 2020 04:57 Go to previous messageGo to next message
Hi, please use:
var myVar : Type = object Type {};
The new keyword is intended to invoke a constructor, which is a special type of QVTo operation that needs to be declared explicitly. In contrast, object allows you to instantiate arbitrary classes on the fly.
Re: [QVTo] No constructor defined, using implicit constructor [message #1831365 is a reply to message #1831364] Tue, 18 August 2020 05:09 Go to previous message
Thanks a lot Christopher for the quick answer :)
Previous Topic:Problems when applying UML profile to an UML model
Next Topic:Adding EAttributes to EStructuralfeatures
Current Time: Sat Jul 19 02:03:53 EDT 2025
Powered by FUDForum. Page generated in 0.03117 seconds
