Home » Eclipse Projects » Oomph » install my own eclipse IDE
install my own eclipse IDE [message #1830796] Tue, 04 August 2020 03:26 Go to next message
I have my own custom eclipse IDE available as a P2 composite repository, this has many components like
ecl_platform
ecl_cdt
ecl_sphinx
... and so many others
So I have updated the org.eclipse.products.setup file to list my IDE pointing to the P2 repository (I would have even created user setup file for the same)
index.php/fa/38724/0/
now my IDE is listed in the product list of oomph installer dialog.
index.php/fa/38722/0/
i have selected this product and installation finished without any errors, but many of the plug-ins listed in my repository are missing in the installation, hence i could not launch my IDE.
for e.g., org.eclipse.equinox.launcher plug-in is missing.
Could you pls help ? Thank you
[Updated on: Tue, 04 August 2020 08:16] by Moderator
Re: install my own eclipse IDE [message #1830800 is a reply to message #1830796] Tue, 04 August 2020 05:22 Go to previous messageGo to next message
I don't see that your p2 director task has any requirements. I only see a repository, but if you don't specify what to install from that repository then nothing will be installed. You should look closely how the existing products specify their p2 directory tasks.
Re: install my own eclipse IDE [message #1830805 is a reply to message #1830800] Tue, 04 August 2020 09:05 Go to previous messageGo to next message
Yes. . after adding the requirement, now it works, i have tried for org.eclipse.platform
what can be done if I want to install all the feature groups from this repository ?
because there are more than 100 feature groups in my repo and I want all of them to be installed.
Should I find all these feature groups and put into the setup as requirements manually ?
Re: install my own eclipse IDE [message #1830810 is a reply to message #1830805] Tue, 04 August 2020 10:24 Go to previous messageGo to next message
Use the Repository Explorer to view the contents of the repository and then drag and drop all the features onto the p2 task:
https://wiki.eclipse.org/Eclipse_Oomph_Authoring#How_to_install_Eclipse_plugins_using_the_P2_Director_and_Repository_Explorer
Re: install my own eclipse IDE [message #1830835 is a reply to message #1830810] Wed, 05 August 2020 01:16 Go to previous messageGo to next message
Thanks that worked!
another issue:
I have two repositories e.g., A, B
A has features 1,2
B has features 1,2,3
I wanted to configure P2 Director task such that features 1,2 are considered from A and feature 3 is considered from B
How can I configure this ?
Note: All these features from both repos are compatible
Re: install my own eclipse IDE [message #1830838 is a reply to message #1830835] Wed, 05 August 2020 01:51 Go to previous messageGo to next message
You can control what's installed either by controlling which repositories are available or by restricting the version range of a requirement such that it is forced to pick something more specific from whatever repositories are available.
A p2 Director task has an advanced property, "Merge Disabled" which is false by default. The only other possibility is to do two separate p2 tasks instead of a single merged p2 task. But I've never tried that in the installer...
Re: install my own eclipse IDE [message #1830938 is a reply to message #1830838] Fri, 07 August 2020 01:55 Go to previous messageGo to next message
I have created two separate P2 director tasks and set "Merge Disabled" to true and installation worked as expected.
index.php/fa/38751/0/
Now the issue is configuration/org.eclipse.equinox.simpleconfigurator/bundles.info is NOT created.
This file gets created when I get all my requirements from
http://download.eclipse.org/releases/photon/201806271001
instead of my repository
so wanted to know in general, what is responsible for creating bundles.info or how this bundles.info is created ?
Re: install my own eclipse IDE [message #1830950 is a reply to message #1830938] Fri, 07 August 2020 04:09 Go to previous message
Perhaps its important to install the product first before installing additional features. So maybe just reordering the p2 Director tasks will do the trick.
Previous Topic:Automate manual steps with Oomph
Next Topic:Issues with ResourceCreationTask
Current Time: Sat Aug 30 11:39:42 EDT 2025
Powered by FUDForum. Page generated in 0.04888 seconds
