Home » Eclipse Projects » GEF » Placing Child Elements inside Nodes in GEF5
Placing Child Elements inside Nodes in GEF5 [message #1829459] Fri, 03 July 2020 22:29 Go to next message
I need to develop a diagram as attached using GEF4/5. I could find only 2 articles on GEF4/5. 1 from Itemis Site and 1 from Frank Blog [gitHub]. In both the examples they teach only 1 Child Node on the Canvas.
index.php/fa/38483/0/
Is there any example similar to UML Diagram using GEF4/5 wherein Class Node contains, Attribute Node and Method Nodes and then has relationships.
Malai
[Updated on: Sat, 04 July 2020 06:42] by Moderator
Re: Placing Child Elements inside Nodes in GEF5 [message #1829474 is a reply to message #1829459] Sat, 04 July 2020 10:02 Go to previous messageGo to next message
Hi Malai,
the Zest Graph Example that is contained within GEF is able to render nested graphs inside nodes of a main graph. Therefore, you can look at that code to see an implementation of multiple layers of controllers. The two methods mainly responsible for this to work are: https://github.com/eclipse/gef/blob/5d8a055f859d92c0e8c0a6ef774bae9101f9bc6c/org.eclipse.gef.zest.fx/src/org/eclipse/gef/zest/fx/parts/NodePart.java#L342 and https://github.com/eclipse/gef/blob/5d8a055f859d92c0e8c0a6ef774bae9101f9bc6c/org.eclipse.gef.zest.fx/src/org/eclipse/gef/zest/fx/parts/NodePart.java#L225
Moreover, you can look at the following slides published by Alexander to get an overview of what you can do with GEF (btw we just call it GEF now, the outdated 3.x codebase is called GEF Legacy): https://www.slideshare.net/AlexanderNyssen/gef-500-from-a-users-perspective
Once you know how to synchronize your semantic model (contents) with the controller hierarchy (parts), then it will be straightforward to work with multiple layers of controllers.
That being said, I believe in most cases you really do not need many layers. IIRC, the tools depicted in the "from a user's perspective" slides are implemented with one or two layers of parts below the root part. The visual hierarchy and the controller hierarchy do not have to match one-to-one. Therefore, a UML-like class "card" could be represented by just one content part, for example, that would be responsible for rendering the box, title, attributes, and methods sections. Relations could be modeled on the same level as the classes.
Matthias
Re: Placing Child Elements inside Nodes in GEF5 [message #1830492 is a reply to message #1829474] Mon, 27 July 2020 15:29 Go to previous messageGo to next message
Hi Matthias
Thanks for your prompt reply. I managed to learn a little bit of GEF5 based on the various examples by Items, Frank and then TMDmaker editor migration code.
I did manage to create 1st draft of my diagram. Thanks for your detailed reply.
i understood the importance of doGetContentChildren(), doAddChildVisual(), doRemoveChildVisual()
Malai
Re: Placing Child Elements inside Nodes in GEF5 [message #1830736 is a reply to message #1830492] Sun, 02 August 2020 02:33 Go to previous messageGo to next message
Hello Malai,
If you are interested in GEF 5.x UML Class Diagram Editor (wherein Class Node contains, Attribute Node and Method Nodes and then has relationships), I suggest you to take a look at the Papyrus GEFx: Papyrus with GEF5.x project presented at the EclipseCon Europe 2019.
- Presentation video (at 27:46) : https://www.youtube.com/watch?v=TmjahlJo76c&feature=youtu.be&t=1666
- Source code on GitHub: https://github.com/eclipsesource/papyrus-gefx
Moreover, you can find further information about GEF 5.x in the further reading section of the GEF Wiki: https://github.com/eclipse/gef/wiki#further-reading
Hope that helps,
Tamás
Re: Placing Child Elements inside Nodes in GEF5 [message #1833283 is a reply to message #1830736] Thu, 08 October 2020 08:11 Go to previous message
Thanks Tamas
We finally managed to create some basic GEF5 Diagrams. Thanks for your link.
I have setup the papyrus code also. But yet to get it compiled and running.
Malai
Previous Topic:Difficuty installing GEF DOT in Eclipse
Next Topic:Snap To Object - GEF5
Current Time: Mon Jul 21 10:47:20 EDT 2025
Powered by FUDForum. Page generated in 0.03576 seconds
