Home » Polarsys » Capella workbench » Reuse components of one model in another model(unable to make links between components of two distinct model.)
Reuse components of one model in another model [message #1830569] Wed, 29 July 2020 05:24 Go to next message
Hi all,
I am trying to reuse components form one model to another model.
For this, in the model explorer view I added my model into the second one.
It works fine.
But now I would like to use component exchange betwwen components of the two models.
When I try to use component exchange I am facing with violation of integrity of the model.
I seems to be not possible to make link between components of two model.
How can I do this ?
Re: Reuse components of one model in another model [message #1830609 is a reply to message #1830569] Wed, 29 July 2020 13:56 Go to previous messageGo to next message
Hi Jean-Pierre,
Not sure what you mean when you say " in the model explorer view I added my model into the second one" but if you're interested in model reuse with capella, you should look at this webinar "Strategies and tools for model reuse with Capella ": https://www.youtube.com/watch?v=I28EhAXe-i8
Re: Reuse components of one model in another model [message #1830639 is a reply to message #1830609] Thu, 30 July 2020 05:25 Go to previous messageGo to next message
Thank you.
In the Model Eplorer view, It's possible to add a reference from one model to another (cf. capture)
This work fine, but it's not possible to add links between this two model.
  • Attachment: addModel.png
    (Size: 70.38KB, Downloaded 129 times)
Re: Reuse components of one model in another model [message #1830664 is a reply to message #1830639] Thu, 30 July 2020 13:21 Go to previous messageGo to next message
I think you should avoid using the Model Explorer view with Capella and stick to the Capella perspective which uses the Project Explorer view, in this one you can't add a model as you do.
I mean, what you are trying to do may be working, but in any case, if your goal is to do resue between Capella models, you should use REC/RPL and librarires.
Re: Reuse components of one model in another model [message #1860050 is a reply to message #1830569] Fri, 14 July 2023 00:38 Go to previous message
AI Spam removed
[Updated on: Wed, 04 October 2023 09:21] by Moderator
Previous Topic:Exporting models to older versions of Capella
Next Topic:Ordering Property values
Current Time: Mon Jul 21 06:13:15 EDT 2025
Powered by FUDForum. Page generated in 0.05607 seconds
