Home » Polarsys » Capella workbench » View properties icon path
View properties icon path [message #1830638] Thu, 30 July 2020 05:20 Go to next message
I would like to change the appearance of my component in capella using the property "icon Path" of the properties view.
I put some icons in a plugin, but I don't known how to reference it in the iconPath properties.
index.php/fa/38693/0/
  • Attachment: iconPath.png
    (Size: 140.66KB, Downloaded 490 times)
Re: View properties icon path [message #1830663 is a reply to message #1830638] Thu, 30 July 2020 13:11 Go to previous messageGo to next message
Hum, I am not sure about this icon path field.
The easiest way to set an image/icon is to use the appearance tab and select an image using the button as shown in the attached image. Before doing that, copy/import the image in your current project.
Stephane
  • Attachment: icon.png
    (Size: 15.04KB, Downloaded 124 times)
Re: View properties icon path [message #1830681 is a reply to message #1830663] Fri, 31 July 2020 03:22 Go to previous messageGo to next message
Thanks.
The icon Path is to change the default one.
For example if you want to change the icon of Physical Component to another one.
But it doesn't work in this version of Capella 1.4
Re: View properties icon path [message #1830696 is a reply to message #1830681] Fri, 31 July 2020 12:46 Go to previous message
ok can you raise a bug here: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Capella ?
Previous Topic:Operational Context Not Showing up
Next Topic:PVMT property value and mass editing view
Current Time: Mon Jul 21 09:24:48 EDT 2025
Powered by FUDForum. Page generated in 0.03539 seconds
