Home » Eclipse Projects » Eclipse Platform » How to add dynamic Hyperlink in SWT shell with eclipse(Hyperlink in SWT TableViewer)
How to add dynamic Hyperlink in SWT shell with eclipse [message #1830400] Fri, 24 July 2020 17:44 Go to next message
Dear Experts,
I have SWT window, and it will launch another SWT shell with TableViewer containing a list of information from Oracle database, each row will have a hyperlink in TableColumn for details of this row.
The second shell is launched, The columns are correctly loaded with data from Oracle, but the link "https://..." does not clickable. I guess the https may be a issue.
I attached the function for the initialization..
One the web, all examples show link with hard coded URL, and actually those samples do not work for me either, links did not launch.
Could you please forward me example for dynamic composed hyperlink?
Thank you very much.
Eric
[Updated on: Fri, 24 July 2020 19:29] by Moderator
Re: How to add dynamic Hyperlink in SWT shell with eclipse [message #1830408 is a reply to message #1830400] Sat, 25 July 2020 02:54 Go to previous messageGo to next message
If you want to open a browser, perhaps use IWorkbenchBrowserSupport instead:
https://git.eclipse.org/c/oomph/org.eclipse.oomph.git/tree/plugins/org.eclipse.oomph.ui/src/org/eclipse/oomph/internal/ui/EarlyStart.java#n140
You could use IWorkbenchBrowserSupport.AS_EXTERNAL to always launch an external browser if that's what you want.
Re: How to add dynamic Hyperlink in SWT shell with eclipse [message #1830418 is a reply to message #1830408] Sat, 25 July 2020 12:29 Go to previous messageGo to next message
When using plain SWT, have a look at the snippets [1], it links to the git sources. Snippet182 and snippet183 (in the link category seem relevant), also Snippet137, Snippet327 and Snippet356 might help you. (search for 'link' on the snippet overview page)
[1] https://www.eclipse.org/swt/snippets/
Re: How to add dynamic Hyperlink in SWT shell with eclipse [message #1830544 is a reply to message #1830418] Tue, 28 July 2020 19:03 Go to previous messageGo to next message
Thank Ed and Rolf for your response. For OOMPH, it is new environment, I installed it, will try late. The Snippets are good, I learned a lot from them. I modified the Snippet148 to my page displaying my web page. the problem is how to launch it.
The link still not reflect to click. I tried both in (TableItem) cell.getItem():
Link: link.addListener (SWT.Selection, event ->{
System.out.println(url); // url printed.
// sn148.open(); // does not work, crashed.
button: public void mouseDoubleClick(MouseEvent e) {
Snippet148 sn148 = new Snippet148();
sn148.setUrl(url);
sn148.open();
in both cases , it crashed. But Snippet148 runs well if I run it alone.
Experts please take a look, and kindly forward instruction.
My Eclipse : Oxygen.3a (4.7.3a), Window 64. Project: WindowBuilder/SWT Desiner/SWT/JFace Java Project
Thank you in advance.
Eric
public void initializeQui() {
TableViewer viewer = new TableViewer(HYSHOPWORKORDER);
viewer.getTable().setHeaderVisible(true);
viewer.getTable().setLinesVisible(true);
viewer.setContentProvider(new ArrayContentProvider());
loadWorkOrder lWO = new loadWorkOrder();
ArrayList<WorkOrder> workOrders = lWO.mxWorkOrderOf1Asset(carNo);
TableColumn column = null;
column = new TableColumn(viewer.getTable(), SWT.NONE);
column.setText("wonum");
column.setWidth(100);
TableViewerColumn Col1 = new TableViewerColumn(viewer, column);
Col1.setLabelProvider(new ColumnLabelProvider(){
String url= "";
String wonum ="";
public String getText(Object element) {
WorkOrder wo = (WorkOrder)element;
url=wo.getUrl();
wonum= wo.getWonum();
return wonum;
public void update(ViewerCell cell) {
TableItem item = (TableItem) cell.getItem();
Hyperlink hyperlink;
wonum = getText(cell.getElement());
Link link = new Link((Composite) cell.getControl(), SWT.NONE);
String text = "<a>" + wonum + "</a>";
link.setText(text);
sn148.setUrl(url);
}); // How to bring up Snippet148?
TableEditor editor = new TableEditor(item.getParent());
editor.grabHorizontal = true;
editor.grabVertical = true;
editor.setEditor(link , item, cell.getColumnIndex());
editor.layout();
// column2, colukmn3, column4
//Instead use Link, I used Button, still not worked:
Button aWorkOrder = new Button((Composite) cell.getControl(), SWT.NONE);
String text = wonum ;
aWorkOrder.setText(text);
aWorkOrder.addMouseListener(new MouseAdapter() {
sn148.setUrl(url);
sn148.open(); // Does not work, crashed. How to bring up Snippet148?
Re: How to add dynamic Hyperlink in SWT shell with eclipse [message #1830545 is a reply to message #1830544] Tue, 28 July 2020 19:41 Go to previous message
Hi All, my problem resolved. it is the first step. I have other question, will post in different topic.
The error is
final Display display = new Display (); changed to Display.getDefault() problem resolved.
Thank you. Thank Ed, thank Rolf .
Eric
Previous Topic:Why does F5 seem to do nothing, but "Refresh" does?
Next Topic:Changing preferences of Project Explorer in RCP
Current Time: Mon Jul 21 08:22:14 EDT 2025
Powered by FUDForum. Page generated in 0.04617 seconds
