Home » Newcomers » Newcomers » Add command button to Eclipse view toolbar without using viewer
Add command button to Eclipse view toolbar without using viewer [message #1830399] Fri, 24 July 2020 16:39 Go to next message
I am trying to create an Eclipse PDE plugin that has a view with a button in the view's tool bar. The view is intended to display text, which will change format when the toolbar button is clicked. I have been trying to work around using a viewer, because none of the viewers match fit my needs. I followed this SO post for reference but have not been able to get the function to work. Is there something wrong with my plugin.xml file? I added the ID of the view as the location URI for the menu contribution, but the plugin is not showing the button in the toolbar as intended.
I have added my plugin.xml, ViewPart class and package structure below for your reference:
<?eclipse version="3.4"?>
<plugin>
   <extension
         point="org.eclipse.ui.views">
      <category
            name="Sample Category"
            id="asher">
      </category>
      <view
            id="asher.views.id.SampleView"
            name="Sample View"
            icon="icons/daffodil.png"
            class="asher.views.SampleView"
            category="asher"
            inject="true">
      </view>
   </extension>
   <extension
         point="org.eclipse.ui.perspectiveExtensions">
      <perspectiveExtension
            targetID="org.eclipse.jdt.ui.JavaPerspective">
         <view
               relative="org.eclipse.ui.views.ProblemView"
               relationship="right"
               ratio="0.5">
         </view>
      </perspectiveExtension>
   </extension>
   <extension
         point="org.eclipse.help.contexts">
      <contexts
            file="contexts.xml">
      </contexts>
   </extension>
      <extension
         point="org.eclipse.ui.commands">
      <category
            id="asher.commands.category"
            name="Parse Category">
      </category>
      <command
            categoryId="asher.commands.category"
            name="Parse"
            id="asher.commands.parseCommand">
      </command>
     <category
            id="asher.commands.unparse.category"
            name="Unparse Category">
     </category>
     <command
            categoryId="asher.commands.unparse.category"
            name="UnParse"
            id="asher.commands.unparseCommand">
      </command>
   </extension>
   <extension
         point="org.eclipse.ui.handlers">
      <handler
            class="asher.handlers.ParseHandler"
            commandId="asher.commands.parseCommand">
      </handler>
      <handler
            class="asher.handlers.UnparseHandler"
            commandId="asher.commands.unparseCommand">
      </handler>
   </extension>
    <extension
         point="org.eclipse.ui.bindings">
      <key
            schemeId="org.eclipse.ui.defaultAcceleratorConfiguration"
            contextId="org.eclipse.ui.contexts.window"
            sequence="M1+6">
      </key>
      <key
            sequence="M1+7">
      </key>
      </extension>
     <extension
         point="org.eclipse.ui.menus">
    <menuContribution
          allPopups="true"
          locationURI="toolbar:asher.views.id.SampleView?after=additions">
         <menu
               id="asher.menus.unparseMenu"
               label="Unparse"
               mnemonic="M">
            <command
                  id="asher.menus.unparseCommand"
                  mnemonic="S"
                  tooltip="Unparse">
            </command>
         </menu>
      </menuContribution>
      </extension>
</plugin>
View Part:
public class SampleView extends ViewPart {
     * The ID of the view as specified by the extension.
    public static final String ID = "asher.views.SampleView";
    @Inject IWorkbench workbench;
    public void createPartControl(Composite parent) {
        Text text = new Text(parent, SWT.READ_ONLY | SWT.V_SCROLL | SWT.H_SCROLL);
         File file = new File("/Users/user/Desktop/install.json");
         Scanner sc;
        try {
            sc = new Scanner(file);
            while (sc.hasNextLine())
                  text.setText(text.getText()+"\n"+sc.nextLine());
            sc.close();
        } catch (FileNotFoundException e) {
            e.printStackTrace();
    public void setFocus() {
Re: Add command button to Eclipse view toolbar without using viewer [message #1830405 is a reply to message #1830399] Sat, 25 July 2020 02:28 Go to previous message
That's a pretty detailed question...
This from the platform looks similar:
https://git.eclipse.org/c/platform/eclipse.platform.debug.git/tree/org.eclipse.debug.examples.ui/plugin.xml#n459
But here the command is not embedded in a menu...
Previous Topic:Eclipse wont install
Next Topic:Eclipse dont find JAVA
Current Time: Mon Jul 21 11:04:18 EDT 2025
Powered by FUDForum. Page generated in 0.04722 seconds
