Home » Newcomers » Newcomers » IllegalStateException and other problems when importing existing gradle(I was importing an existing gradle so I could start work on a 1.12.2 Minecraft mod and I got this error which I can't figure out how to fix.)
IllegalStateException and other problems when importing existing gradle [message #1830079] Thu, 16 July 2020 22:04 Go to next message
As the topic description says: I was importing an existing gradle so I could start work on a 1.12.2 Minecraft mod and I got this error which I can't figure out how to fix.
I simply downloaded the Mod Development Kit from the official Minecraft Forge site and went to import the project folder with the extracted development kit in it into eclipse and after a bit of loading I got this error.
If it helps I also got these errors:
The import net cannot be resolved
Mod cannot be resolved to a type
and,
EventHandler cannot be resolved to a type
I don't know what any of this means, it just looks very confusing and concerning and I feel too uneducated to figure this out so I am asking on here.
java.lang.IllegalStateException: Could not find tools.jar. Please check that C:\Program Files\Java\jre1.8.0_261 contains a valid JDK installation.
	at org.gradle.api.internal.tasks.compile.JdkTools.<init>(JdkTools.java:66)
	at org.gradle.api.internal.tasks.compile.JdkTools.current(JdkTools.java:52)
	at org.gradle.api.internal.tasks.compile.JavaHomeBasedJavaCompilerFactory$SystemJavaCompilerFactory.create(JavaHomeBasedJavaCompilerFactory.java:80)
	at org.gradle.api.internal.tasks.compile.JavaHomeBasedJavaCompilerFactory$SystemJavaCompilerFactory.create(JavaHomeBasedJavaCompilerFactory.java:77)
	at org.gradle.api.internal.tasks.compile.JavaHomeBasedJavaCompilerFactory.findCompiler(JavaHomeBasedJavaCompilerFactory.java:57)
	at org.gradle.api.internal.tasks.compile.JavaHomeBasedJavaCompilerFactory.create(JavaHomeBasedJavaCompilerFactory.java:44)
	at org.gradle.api.internal.tasks.compile.JavaHomeBasedJavaCompilerFactory.create(JavaHomeBasedJavaCompilerFactory.java:27)
	at org.gradle.api.internal.tasks.compile.JdkJavaCompiler.createCompileTask(JdkJavaCompiler.java:59)
	at org.gradle.api.internal.tasks.compile.JdkJavaCompiler.execute(JdkJavaCompiler.java:49)
	at org.gradle.api.internal.tasks.compile.JdkJavaCompiler.execute(JdkJavaCompiler.java:36)
	at org.gradle.api.internal.tasks.compile.NormalizingJavaCompiler.delegateAndHandleErrors(NormalizingJavaCompiler.java:100)
	at org.gradle.api.internal.tasks.compile.NormalizingJavaCompiler.execute(NormalizingJavaCompiler.java:52)
	at org.gradle.api.internal.tasks.compile.NormalizingJavaCompiler.execute(NormalizingJavaCompiler.java:38)
	at org.gradle.api.internal.tasks.compile.AnnotationProcessorDiscoveringCompiler.execute(AnnotationProcessorDiscoveringCompiler.java:49)
	at org.gradle.api.internal.tasks.compile.AnnotationProcessorDiscoveringCompiler.execute(AnnotationProcessorDiscoveringCompiler.java:35)
	at org.gradle.api.internal.tasks.compile.CleaningJavaCompilerSupport.execute(CleaningJavaCompilerSupport.java:40)
	at org.gradle.api.internal.tasks.compile.CleaningJavaCompilerSupport.execute(CleaningJavaCompilerSupport.java:27)
	at org.gradle.api.tasks.compile.JavaCompile.performCompilation(JavaCompile.java:156)
	at org.gradle.api.tasks.compile.JavaCompile.compile(JavaCompile.java:141)
	at net.minecraftforge.gradle.userdev.tasks.HackyJavaCompile.doHackyCompile(HackyJavaCompile.java:70)
	at net.minecraftforge.gradle.userdev.MinecraftUserRepo.compileJava(MinecraftUserRepo.java:1292)
	at net.minecraftforge.gradle.userdev.MinecraftUserRepo.findRaw(MinecraftUserRepo.java:629)
	at net.minecraftforge.gradle.userdev.MinecraftUserRepo.findFile(MinecraftUserRepo.java:409)
	at net.minecraftforge.gradle.common.util.BaseRepo.getArtifact(BaseRepo.java:81)
	at net.minecraftforge.gradle.common.util.BaseRepo.getArtifact(BaseRepo.java:41)
	at net.minecraftforge.gradle.common.util.BaseRepo$Builder$1.lambda$getArtifact$0(BaseRepo.java:127)
	at java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
	at java.util.ArrayList$ArrayListSpliterator.tryAdvance(Unknown Source)
	at java.util.stream.ReferencePipeline.forEachWithCancel(Unknown Source)
	at java.util.stream.AbstractPipeline.copyIntoWithCancel(Unknown Source)
	at java.util.stream.AbstractPipeline.copyInto(Unknown Source)
	at java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
	at java.util.stream.FindOps$FindOp.evaluateSequential(Unknown Source)
	at java.util.stream.AbstractPipeline.evaluate(Unknown Source)
	at java.util.stream.ReferencePipeline.findFirst(Unknown Source)
	at net.minecraftforge.gradle.common.util.BaseRepo$Builder$1.getArtifact(BaseRepo.java:127)
	at net.minecraftforge.gradle.common.util.BaseRepo$Builder$1.getArtifact(BaseRepo.java:124)
	at com.amadornes.artifactural.base.repository.ArtifactProviderBuilder$Complete.getArtifact(ArtifactProviderBuilder.java:92)
	at com.amadornes.artifactural.base.repository.SimpleRepository.getArtifact(SimpleRepository.java:41)
	at com.amadornes.artifactural.gradle.GradleRepositoryAdapter$GeneratingFileResourceRepository.findArtifact(GradleRepositoryAdapter.java:298)
	at com.amadornes.artifactural.gradle.GradleRepositoryAdapter$GeneratingFileResourceRepository.resource(GradleRepositoryAdapter.java:277)
	at com.amadornes.artifactural.gradle.GradleRepositoryAdapter$GeneratingFileResourceRepository.resource(GradleRepositoryAdapter.java:243)
	at org.gradle.api.internal.artifacts.repositories.resolver.DefaultExternalResourceArtifactResolver.staticResourceExists(DefaultExternalResourceArtifactResolver.java:83)
	at org.gradle.api.internal.artifacts.repositories.resolver.DefaultExternalResourceArtifactResolver.artifactExists(DefaultExternalResourceArtifactResolver.java:71)
	at org.gradle.api.internal.artifacts.repositories.DefaultMavenLocalArtifactRepository$MavenLocalMetadataValidator.isUsableModule(DefaultMavenLocalArtifactRepository.java:119)
	at org.gradle.api.internal.artifacts.repositories.metadata.DefaultMavenPomMetadataSource.parseMetaDataFromResource(DefaultMavenPomMetadataSource.java:65)
	at org.gradle.api.internal.artifacts.repositories.metadata.DefaultMavenPomMetadataSource.parseMetaDataFromResource(DefaultMavenPomMetadataSource.java:38)
	at org.gradle.api.internal.artifacts.repositories.metadata.AbstractRepositoryMetadataSource.parseMetaDataFromArtifact(AbstractRepositoryMetadataSource.java:72)
	at org.gradle.api.internal.artifacts.repositories.metadata.AbstractRepositoryMetadataSource.create(AbstractRepositoryMetadataSource.java:59)
	at org.gradle.api.internal.artifacts.repositories.resolver.ExternalResourceResolver.resolveStaticDependency(ExternalResourceResolver.java:244)
	at org.gradle.api.internal.artifacts.repositories.resolver.MavenResolver.doResolveComponentMetaData(MavenResolver.java:125)
	at org.gradle.api.internal.artifacts.repositories.resolver.ExternalResourceResolver$RemoteRepositoryAccess.resolveComponentMetaData(ExternalResourceResolver.java:445)
	at com.amadornes.artifactural.gradle.GradleRepositoryAdapter$1$1.resolveComponentMetaData(GradleRepositoryAdapter.java:178)
	at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.CachingModuleComponentRepository$ResolveAndCacheRepositoryAccess.resolveComponentMetaData(CachingModuleComponentRepository.java:378)
	at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.LocalModuleComponentRepository$LocalAccess.resolveComponentMetaData(LocalModuleComponentRepository.java:77)
	at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.ErrorHandlingModuleComponentRepository$ErrorHandlingModuleComponentRepositoryAccess.resolveComponentMetaData(ErrorHandlingModuleComponentRepository.java:138)
	at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.ComponentMetaDataResolveState.process(ComponentMetaDataResolveState.java:67)
	at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.ComponentMetaDataResolveState.resolve(ComponentMetaDataResolveState.java:46)
	at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.RepositoryChainComponentMetaDataResolver.findBestMatch(RepositoryChainComponentMetaDataResolver.java:138)
	at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.RepositoryChainComponentMetaDataResolver.findBestMatch(RepositoryChainComponentMetaDataResolver.java:119)
	at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.RepositoryChainComponentMetaDataResolver.resolveModule(RepositoryChainComponentMetaDataResolver.java:92)
	at org.gradle.api.internal.artifacts.ivyservice.ivyresolve.RepositoryChainComponentMetaDataResolver.resolve(RepositoryChainComponentMetaDataResolver.java:63)
	at org.gradle.api.internal.artifacts.ivyservice.resolveengine.ComponentResolversChain$ComponentMetaDataResolverChain.resolve(ComponentResolversChain.java:94)
	at org.gradle.api.internal.artifacts.ivyservice.clientmodule.ClientModuleResolver.resolve(ClientModuleResolver.java:62)
	at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.ComponentState.resolve(ComponentState.java:188)
	at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.ComponentState.getMetadata(ComponentState.java:141)
	at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.EdgeState.calculateTargetConfigurations(EdgeState.java:156)
	at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.EdgeState.attachToTargetConfigurations(EdgeState.java:112)
	at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.DependencyGraphBuilder.attachToTargetRevisionsSerially(DependencyGraphBuilder.java:306)
	at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.DependencyGraphBuilder.resolveEdges(DependencyGraphBuilder.java:193)
	at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.DependencyGraphBuilder.traverseGraph(DependencyGraphBuilder.java:146)
	at org.gradle.api.internal.artifacts.ivyservice.resolveengine.graph.builder.DependencyGraphBuilder.resolve(DependencyGraphBuilder.java:117)
	at org.gradle.api.internal.artifacts.ivyservice.resolveengine.DefaultArtifactDependencyResolver.resolve(DefaultArtifactDependencyResolver.java:119)
	at org.gradle.api.internal.artifacts.ivyservice.DefaultConfigurationResolver.resolveGraph(DefaultConfigurationResolver.java:167)
	at org.gradle.api.internal.artifacts.ivyservice.ShortCircuitEmptyConfigurationResolver.resolveGraph(ShortCircuitEmptyConfigurationResolver.java:82)
	at org.gradle.api.internal.artifacts.ivyservice.ErrorHandlingConfigurationResolver.resolveGraph(ErrorHandlingConfigurationResolver.java:66)
	at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration$5.run(DefaultConfiguration.java:534)
	at org.gradle.internal.operations.DefaultBuildOperationExecutor$RunnableBuildOperationWorker.execute(DefaultBuildOperationExecutor.java:300)
	at org.gradle.internal.operations.DefaultBuildOperationExecutor$RunnableBuildOperationWorker.execute(DefaultBuildOperationExecutor.java:292)
	at org.gradle.internal.operations.DefaultBuildOperationExecutor.execute(DefaultBuildOperationExecutor.java:174)
	at org.gradle.internal.operations.DefaultBuildOperationExecutor.run(DefaultBuildOperationExecutor.java:90)
	at org.gradle.internal.operations.DelegatingBuildOperationExecutor.run(DelegatingBuildOperationExecutor.java:31)
	at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration.resolveGraphIfRequired(DefaultConfiguration.java:525)
	at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration.resolveToStateOrLater(DefaultConfiguration.java:510)
	at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration.access$1800(DefaultConfiguration.java:125)
	at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration$ConfigurationFileCollection.getSelectedArtifacts(DefaultConfiguration.java:1033)
	at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration$ConfigurationFileCollection.getFiles(DefaultConfiguration.java:1021)
	at org.gradle.api.internal.file.AbstractFileCollection.contains(AbstractFileCollection.java:86)
	at org.gradle.api.internal.artifacts.configurations.DefaultConfiguration.contains(DefaultConfiguration.java:450)
	at org.gradle.api.internal.file.CompositeFileCollection.contains(CompositeFileCollection.java:90)
	at org.gradle.plugins.ide.eclipse.model.internal.SourceFoldersCreator.containsAll(SourceFoldersCreator.java:213)
	at org.gradle.plugins.ide.eclipse.model.internal.SourceFoldersCreator.containsOutputOf(SourceFoldersCreator.java:205)
	at org.gradle.plugins.ide.eclipse.model.internal.SourceFoldersCreator.getSourceSetUsages(SourceFoldersCreator.java:195)
	at org.gradle.plugins.ide.eclipse.model.internal.SourceFoldersCreator.projectRelativeFolders(SourceFoldersCreator.java:116)
	at org.gradle.plugins.ide.eclipse.model.internal.SourceFoldersCreator.createSourceFolders(SourceFoldersCreator.java:61)
	at org.gradle.plugins.ide.eclipse.model.internal.ClasspathFactory.createSourceFolders(ClasspathFactory.java:57)
	at org.gradle.plugins.ide.eclipse.model.internal.ClasspathFactory.createEntries(ClasspathFactory.java:45)
	at org.gradle.plugins.ide.eclipse.model.EclipseClasspath.resolveDependencies(EclipseClasspath.java:326)
	at org.gradle.plugins.ide.eclipse.model.EclipseClasspath.mergeXmlClasspath(EclipseClasspath.java:331)
	at org.gradle.plugins.ide.internal.tooling.EclipseModelBuilder.populate(EclipseModelBuilder.java:158)
	at org.gradle.plugins.ide.internal.tooling.EclipseModelBuilder.buildAll(EclipseModelBuilder.java:104)
	at org.gradle.plugins.ide.internal.tooling.EclipseModelBuilder.buildAll(EclipseModelBuilder.java:72)
	at org.gradle.tooling.internal.provider.runner.DefaultBuildController.getModel(DefaultBuildController.java:79)
	at org.gradle.tooling.internal.consumer.connection.InternalBuildActionAdapter$2.getModel(InternalBuildActionAdapter.java:76)
	at org.gradle.tooling.internal.consumer.connection.BuildControllerAdapter.getModel(BuildControllerAdapter.java:62)
	at org.gradle.tooling.internal.consumer.connection.AbstractBuildController.getModel(AbstractBuildController.java:44)
	at org.eclipse.buildship.core.internal.workspace.CompositeModelQuery.collectRootModels(CompositeModelQuery.java:58)
	at org.eclipse.buildship.core.internal.workspace.CompositeModelQuery.execute(CompositeModelQuery.java:50)
	at org.eclipse.buildship.core.internal.workspace.CompositeModelQuery.execute(CompositeModelQuery.java:27)
	at org.gradle.tooling.internal.consumer.connection.InternalBuildActionAdapter.execute(InternalBuildActionAdapter.java:79)
	at org.gradle.tooling.internal.provider.runner.ClientProvidedBuildActionRunner.buildResult(ClientProvidedBuildActionRunner.java:81)
	at org.gradle.tooling.internal.provider.runner.ClientProvidedBuildActionRunner.access$100(ClientProvidedBuildActionRunner.java:38)
	at org.gradle.tooling.internal.provider.runner.ClientProvidedBuildActionRunner$1.buildFinished(ClientProvidedBuildActionRunner.java:62)
	at org.gradle.internal.dispatch.ReflectionDispatch.dispatch(ReflectionDispatch.java:35)
	at org.gradle.internal.dispatch.ReflectionDispatch.dispatch(ReflectionDispatch.java:24)
	at org.gradle.internal.event.DefaultListenerManager$ListenerDetails.dispatch(DefaultListenerManager.java:370)
	at org.gradle.internal.event.DefaultListenerManager$ListenerDetails.dispatch(DefaultListenerManager.java:352)
	at org.gradle.internal.event.AbstractBroadcastDispatch.dispatch(AbstractBroadcastDispatch.java:58)
	at org.gradle.internal.event.DefaultListenerManager$EventBroadcast$ListenerDispatch.dispatch(DefaultListenerManager.java:340)
	at org.gradle.internal.event.DefaultListenerManager$EventBroadcast$ListenerDispatch.dispatch(DefaultListenerManager.java:327)
	at org.gradle.internal.event.AbstractBroadcastDispatch.dispatch(AbstractBroadcastDispatch.java:42)
	at org.gradle.internal.event.BroadcastDispatch$SingletonDispatch.dispatch(BroadcastDispatch.java:230)
	at org.gradle.internal.event.BroadcastDispatch$SingletonDispatch.dispatch(BroadcastDispatch.java:149)
	at org.gradle.internal.event.BroadcastDispatch$CompositeDispatch.dispatch(BroadcastDispatch.java:324)
	at org.gradle.internal.event.BroadcastDispatch$CompositeDispatch.dispatch(BroadcastDispatch.java:234)
	at org.gradle.internal.event.ListenerBroadcast.dispatch(ListenerBroadcast.java:140)
	at org.gradle.internal.event.ListenerBroadcast.dispatch(ListenerBroadcast.java:37)
	at org.gradle.internal.dispatch.ProxyDispatchAdapter$DispatchingInvocationHandler.invoke(ProxyDispatchAdapter.java:93)
	at com.sun.proxy.$Proxy16.buildFinished(Unknown Source)
	at org.gradle.initialization.DefaultGradleLauncher.finishBuild(DefaultGradleLauncher.java:162)
	at org.gradle.initialization.DefaultGradleLauncher.finishBuild(DefaultGradleLauncher.java:128)
	at org.gradle.internal.invocation.GradleBuildController$2.call(GradleBuildController.java:87)
	at org.gradle.internal.invocation.GradleBuildController$2.call(GradleBuildController.java:83)
	at org.gradle.internal.work.DefaultWorkerLeaseService.withLocks(DefaultWorkerLeaseService.java:152)
	at org.gradle.internal.work.StopShieldingWorkerLeaseService.withLocks(StopShieldingWorkerLeaseService.java:38)
	at org.gradle.internal.invocation.GradleBuildController.doBuild(GradleBuildController.java:96)
	at org.gradle.internal.invocation.GradleBuildController.configure(GradleBuildController.java:83)
	at org.gradle.tooling.internal.provider.runner.ClientProvidedBuildActionRunner.run(ClientProvidedBuildActionRunner.java:70)
	at org.gradle.launcher.exec.ChainingBuildActionRunner.run(ChainingBuildActionRunner.java:35)
	at org.gradle.tooling.internal.provider.ValidatingBuildActionRunner.run(ValidatingBuildActionRunner.java:32)
	at org.gradle.launcher.exec.RunAsBuildOperationBuildActionRunner$3.run(RunAsBuildOperationBuildActionRunner.java:47)
	at org.gradle.launcher.exec.RunAsBuildOperationBuildActionRunner.run(RunAsBuildOperationBuildActionRunner.java:43)
	at org.gradle.tooling.internal.provider.SubscribableBuildActionRunner.run(SubscribableBuildActionRunner.java:51)
	at org.gradle.launcher.exec.InProcessBuildActionExecuter$1.transform(InProcessBuildActionExecuter.java:50)
	at org.gradle.launcher.exec.InProcessBuildActionExecuter$1.transform(InProcessBuildActionExecuter.java:46)
	at org.gradle.composite.internal.DefaultRootBuildState.run(DefaultRootBuildState.java:74)
	at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:46)
	at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:32)
	at org.gradle.launcher.exec.BuildTreeScopeBuildActionExecuter.execute(BuildTreeScopeBuildActionExecuter.java:39)
	at org.gradle.launcher.exec.BuildTreeScopeBuildActionExecuter.execute(BuildTreeScopeBuildActionExecuter.java:25)
	at org.gradle.tooling.internal.provider.ContinuousBuildActionExecuter.execute(ContinuousBuildActionExecuter.java:80)
	at org.gradle.tooling.internal.provider.ContinuousBuildActionExecuter.execute(ContinuousBuildActionExecuter.java:53)
	at org.gradle.tooling.internal.provider.ServicesSetupBuildActionExecuter.execute(ServicesSetupBuildActionExecuter.java:62)
	at org.gradle.tooling.internal.provider.ServicesSetupBuildActionExecuter.execute(ServicesSetupBuildActionExecuter.java:34)
	at org.gradle.tooling.internal.provider.GradleThreadBuildActionExecuter.execute(GradleThreadBuildActionExecuter.java:36)
	at org.gradle.tooling.internal.provider.GradleThreadBuildActionExecuter.execute(GradleThreadBuildActionExecuter.java:25)
	at org.gradle.tooling.internal.provider.ParallelismConfigurationBuildActionExecuter.execute(ParallelismConfigurationBuildActionExecuter.java:43)
	at org.gradle.tooling.internal.provider.ParallelismConfigurationBuildActionExecuter.execute(ParallelismConfigurationBuildActionExecuter.java:29)
	at org.gradle.tooling.internal.provider.StartParamsValidatingActionExecuter.execute(StartParamsValidatingActionExecuter.java:59)
	at org.gradle.tooling.internal.provider.StartParamsValidatingActionExecuter.execute(StartParamsValidatingActionExecuter.java:31)
	at org.gradle.tooling.internal.provider.SessionFailureReportingActionExecuter.execute(SessionFailureReportingActionExecuter.java:59)
	at org.gradle.tooling.internal.provider.SessionFailureReportingActionExecuter.execute(SessionFailureReportingActionExecuter.java:44)
	at org.gradle.tooling.internal.provider.SetupLoggingActionExecuter.execute(SetupLoggingActionExecuter.java:46)
	at org.gradle.tooling.internal.provider.SetupLoggingActionExecuter.execute(SetupLoggingActionExecuter.java:30)
	at org.gradle.launcher.daemon.server.exec.ExecuteBuild.doBuild(ExecuteBuild.java:67)
	at org.gradle.launcher.daemon.server.exec.BuildCommandOnly.execute(BuildCommandOnly.java:36)
	at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:122)
	at org.gradle.launcher.daemon.server.exec.WatchForDisconnection.execute(WatchForDisconnection.java:37)
	at org.gradle.launcher.daemon.server.exec.ResetDeprecationLogger.execute(ResetDeprecationLogger.java:26)
	at org.gradle.launcher.daemon.server.exec.RequestStopIfSingleUsedDaemon.execute(RequestStopIfSingleUsedDaemon.java:34)
	at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java:74)
	at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java:72)
	at org.gradle.util.Swapper.swap(Swapper.java:38)
	at org.gradle.launcher.daemon.server.exec.ForwardClientInput.execute(ForwardClientInput.java:72)
	at org.gradle.launcher.daemon.server.exec.LogAndCheckHealth.execute(LogAndCheckHealth.java:55)
	at org.gradle.launcher.daemon.server.exec.LogToClient.doBuild(LogToClient.java:62)
	at org.gradle.launcher.daemon.server.exec.EstablishBuildEnvironment.doBuild(EstablishBuildEnvironment.java:82)
	at org.gradle.launcher.daemon.server.exec.StartBuildOrRespondWithBusy$1.run(StartBuildOrRespondWithBusy.java:50)
	at org.gradle.launcher.daemon.server.DaemonStateCoordinator$1.run(DaemonStateCoordinator.java:295)
	at org.gradle.internal.concurrent.ExecutorPolicy$CatchAndRecordFailures.onExecute(ExecutorPolicy.java:63)
	at org.gradle.internal.concurrent.ManagedExecutorImpl$1.run(ManagedExecutorImpl.java:46)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.gradle.internal.concurrent.ThreadFactoryImpl$ManagedThreadRunnable.run(ThreadFactoryImpl.java:55)
Here is what I have tried to do to fix this: Refreshing the project, cleaning the project, updating java.
Here is my Mod Development Kit version: 1.12.2-14.23.5.2854
Re: IllegalStateException and other problems when importing existing gradle [message #1830080 is a reply to message #1830079] Thu, 16 July 2020 23:59 Go to previous message
If you're working with gradle to build Java, you need a Java Development Kit (JDK), not just a Java Runtime Environment (JRE). Gradle uses the compiler that's only found in the JDK, not the JRE.
Previous Topic:PIC micro-controller plugin in Eclipse
Next Topic:How to format build.properities for eclipse plugin export
Current Time: Mon Jul 21 08:35:20 EDT 2025
Powered by FUDForum. Page generated in 0.10030 seconds
