Home » Eclipse Projects » GEF » problem about save the canvas
problem about save the canvas [message #182988] Mon, 30 May 2005 21:25 Go to next message
Originally posted by: tankun.web.de
hello:
i want save the canvas of my editor.and i did following things.
in the Model class:
public InputStream getAsStream() throws IOException {
ByteArrayOutputStream os = new ByteArrayOutputStream();
ObjectOutputStream out = new ObjectOutputStream(os);
out.writeObject(this);
out.close();
InputStream istream = new ByteArrayInputStream(os.toByteArray());
os.close();
return istream;
public static Diagram makeFromStream(InputStream istream) throws
IOException, ClassNotFoundException {
ObjectInputStream ois = new ObjectInputStream(istream);
Diagram diagram = (Diagram) ois.readObject();
ois.close();
return diagram;
and in the Editor class:
public void doSave(IProgressMonitor monitor) {
try {
IFile file = ((IFileEditorInput) getEditorInput()).getFile();
file.setContents(this.diagram.getAsStream(), true, false,
monitor);
getCommandStack().markSaveLocation();
catch (Exception e) {
e.printStackTrace();
public void doSaveAs() {
SaveAsDialog dialog = new
SaveAsDialog(getSite().getWorkbenchWindow().getShell());
dialog.setOriginalFile(((IFileEditorInput)
getEditorInput()).getFile());
dialog.open();
IPath path = dialog.getResult();
if (path == null)
return;
IWorkspace workspace = ResourcesPlugin.getWorkspace();
final IFile file = workspace.getRoot().getFile(path);
WorkspaceModifyOperation op = new WorkspaceModifyOperation() {
public void execute(final IProgressMonitor monitor) throws
CoreException {
try {
file.create(diagram.getAsStream(), true, monitor);
try {
new
ProgressMonitorDialog(getSite().getWorkbenchWindow().getShel l()).run(false,
true, op);
setInput(new FileEditorInput((IFile) file));
public void gotoMarker(IMarker marker) {
public boolean isDirty() {
// rely on the command stack to determine dirty flag
return getCommandStack().isDirty();
public boolean isSaveAsAllowed() {
// allow Save As
return true;
but it come always the warning when the editor start:
java.io.EOFException
at
java.io.ObjectInputStream$PeekInputStream.readFully(ObjectIn putStream.java:2165)
at
java.io.ObjectInputStream$BlockDataInputStream.readShort(Obj ectInputStream.java:2631)
at java.io.ObjectInputStream.readStreamHeader(ObjectInputStream .java:734)
at java.io.ObjectInputStream.<init>(ObjectInputStream.java:253)
at model.Diagram.makeFromStream(Diagram.java:65)
at ui.Geditor.setInput(Geditor.java:82)
at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:292)
at
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:719)
at
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:788)
at org.eclipse.ui.internal.EditorManager.access$12(EditorManage r.java:774)
at org.eclipse.ui.internal.EditorManager$9.run(EditorManager.ja va:959)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:933)
at org.eclipse.ui.internal.EditorManager$8.run(EditorManager.ja va:926)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:922)
at
org.eclipse.ui.internal.EditorManager.restoreEditorState(Edi torManager.java:1498)
at
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:885)
at
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2470)
at
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1372)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1224)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 185)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:1096 )
at
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1029)
at
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:167)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:652)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:819)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1325)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
and when it closed:
java.io.NotSerializableException:
org.eclipse.ui.views.properties.TextPropertyDescriptor
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.j ava:1054)
at java.io.ObjectOutputStream.writeArray(ObjectOutputStream.jav a:1224)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.j ava:1050)
at
java.io.ObjectOutputStream.defaultWriteFields(ObjectOutputSt ream.java:1332)
at
java.io.ObjectOutputStream.writeSerialData(ObjectOutputStrea m.java:1304)
at
java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputS tream.java:1247)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.j ava:1052)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.ja va:278)
at java.util.ArrayList.writeObject(ArrayList.java:529)
at
at
at java.io.ObjectStreamClass.invokeWriteObject(ObjectStreamClas s.java:809)
at
java.io.ObjectOutputStream.writeSerialData(ObjectOutputStrea m.java:1296)
at
at
at
at
at model.Diagram.getAsStream(Diagram.java:57)
at ui.Geditor.doSave(Geditor.java:106)
at org.eclipse.ui.internal.SaveableHelper$1.run(SaveableHelper. java:88)
at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper. java:109)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:303)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:253)
at
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:588)
at
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:585)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:1653)
at
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:115)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:93)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1104)
at
org.eclipse.ui.internal.EditorManager.saveEditor(EditorManag er.java:1112)
at
org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:974)
at
org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:959)
at org.eclipse.ui.internal.EditorPane.doHide(EditorPane.java:95 )
at org.eclipse.ui.internal.PartStack.close(PartStack.java:339)
at org.eclipse.ui.internal.EditorStack.close(EditorStack.java:2 38)
at org.eclipse.ui.internal.PartStack$1.close(PartStack.java:74)
at
org.eclipse.ui.internal.presentations.DefaultPartPresentatio n$1.closeButtonPressed(DefaultPartPresentation.java:107)
at
org.eclipse.ui.internal.presentations.PaneFolder.notifyClose Listeners(PaneFolder.java:484)
at
org.eclipse.ui.internal.presentations.PaneFolder$3.close(Pan eFolder.java:169)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:20 75)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:291)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2773)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2432)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
at
at
at
at
at
please help me ,where is the problem?and what should i do?
Re: problem about save the canvas [message #183003 is a reply to message #182988] Mon, 30 May 2005 22:04 Go to previous message
I take it you meant that you're trying to save the model and not the canvas
itself. Open up the saved file in a text editor to see if there's anything
in there. Catch the exception in makeFromStream, and create a new Diagram
if you couldn't read the one loaded. That way your editor will still come
up. Then try saving it again and see if it's saving fine.
Anyway, this is all I/O stuff, and not really GEF-related.
"Kun Tan" <tankun@web.de> wrote in message
news:f1cd050ae1b441c3e92362b4f8c883d6$1@www.eclipse.org...
> hello:
> in the Model class:
> out.close();
> os.close();
> return istream;
> ois.close();
> return diagram;
> try {
> monitor);
> dialog.open();
> if (path == null)
> return;
> CoreException {
> try {
> try {
> new
> true, op);
> // allow Save As
> return true;
> at
165)
> at
ava:2631)
> at
> at
788)
> at
:616)
> at
33)
> at
> at
1498)
> at
> at
> at
72)
> at
:616)
> at
..java:167)
> at
a:652)
> at
> at
java:335)
> at
> at
> at
> at
..java:25)
> and when it closed:
> at
> at
> at
> at
> at
..java:25)
> at
> at
> at
> at
> at
> at
a:303)
> at
> at
> at
elper.java:115)
> at
> at
> at
> at
> at
lder.java:484)
> at
> at
> at
java:335)
> at
> at
> at
> at
..java:25)
Previous Topic:About SWT AND JFace
Next Topic:How to create a MultipageEditor with a GEF page?
Current Time: Thu Jul 17 03:38:28 EDT 2025
Powered by FUDForum. Page generated in 0.29650 seconds
