Home » Language IDEs » C / C++ IDE (CDT) » problem with integration of QT plugin - eclipse 2020-06 (I need help to integrate properly qt plugins, allowing student accessing to graphic components directly inside eclipse)
problem with integration of QT plugin - eclipse 2020-06 [message #1829489] Sat, 04 July 2020 21:42 Go to next message
Hello, I would need help integrating a qt plugin into eclipse. It is a plugin offered a few years ago by trolltech (former name for QT group).
The archive is called qt-eclipse-integration-linux.x86_64-1.6.1.tar.gz which can be found at: https://github.com/ygpark/nokia-qteclipse/find/ Master
I followed the installation instructions by decompressing the archive and copying all the elements of the "plugins" directory into the "dropins" directory.
This plugin is supposed to integrate the basic QT graphic components inside the eclipse. This plugin worked under old versions of eclipse in 32bits.
I sincerely hope to achieve this integration for an educational purpose that allows students to directly access the components of basic projects.
Currently, installing the plugin has no effect. we do not observe any error message, no message in the log files.
I would like to have help or at least know if this installation is possible or not and for what reason
Thank you very much,
ps : I didnt find topic on this subject, if there alreqady is one, please forgive me. I am new here
Re: problem with integration of QT plugin - eclipse 2020-06 [message #1829513 is a reply to message #1829489] Mon, 06 July 2020 00:54 Go to previous messageGo to next message
You should ask the plugin developers
https://github.com/ygpark/nokia-qteclipse/issues
Re: problem with integration of QT plugin - eclipse 2020-06 [message #1829953 is a reply to message #1829513] Tue, 14 July 2020 13:39 Go to previous messageGo to next message
As of 7/14/2020 https://github.com/ygpark/nokia-qteclipse/issues is unusable
Re: problem with integration of QT plugin - eclipse 2020-06 [message #1829966 is a reply to message #1829953] Tue, 14 July 2020 18:11 Go to previous message
The code downloaded by the OP from https://github.com/ygpark/nokia-qteclipse is no longer supported.
In fact, it appears to have been so for some time.
https://stackoverflow.com/a/12618419/3312726
Previous Topic:Adding Qt to CDT - libraries??
Next Topic:Implementing GTK in Eclipse DELETED
Current Time: Mon Jul 21 12:25:54 EDT 2025
Powered by FUDForum. Page generated in 0.08063 seconds
