Home » Newcomers » Newcomers » What JVM config options does Eclipse insert into application?
What JVM config options does Eclipse insert into application? [message #1829732] Thu, 09 July 2020 12:39 Go to next message
I have a java application which behaves differently when I launch it from Eclipse than when I launch it from a standalone jar file. For instance, running standalone it hangs (seems to be a out of memory error, but I'm not sure). If I run it the exact same way from eclipse it runs fine with no errors.
I'm just wondering how does Eclipse launch applications, does it insert hidden config options into the JVM (like -xmx or -xms)?
Re: What JVM config options does Eclipse insert into application? [message #1829743 is a reply to message #1829732] Thu, 09 July 2020 21:16 Go to previous messageGo to next message
You can bring up the Properties for the node in the Debug view that represents your Java runtime to see the entire command invocation that launched it. Most of what's used in what you specified in your application's launch configuration.
Re: What JVM config options does Eclipse insert into application? [message #1829752 is a reply to message #1829743] Fri, 10 July 2020 04:20 Go to previous messageGo to next message
Thanks for the answer.
You mean Run/Debug settings? I looked there, but I don't see any special settings. Everything is default.
Is there any other thing that Eclipse does that makes the java application run differently than when it runs from a standalone jar file?
Re: What JVM config options does Eclipse insert into application? [message #1829753 is a reply to message #1829752] Fri, 10 July 2020 04:27 Go to previous messageGo to next message
No, not in the settings. When you Run or Debug something, the Debug view of the Debug perspective will show a tree node for that launched process. In the context menu of the child node, there is "Properties..." item and it bring up a dialog that includes things like the "Command Line:" which shows exactly how the process was launched. You can compare that to your manual command line launch.
Re: What JVM config options does Eclipse insert into application? [message #1829759 is a reply to message #1829753] Fri, 10 July 2020 05:23 Go to previous message
Yes, I see it now. Thanks very much. That's what I was looking for ;)
Previous Topic:Windows 10 Java 64
Next Topic:PyDev on Eclipse 2020-06 installation failed
Current Time: Mon Jul 21 07:04:51 EDT 2025
Powered by FUDForum. Page generated in 0.06908 seconds
