Home » Polarsys » Arcadia » Depiction of continuous flows(Is this representation useful?)
Depiction of continuous flows [message #1829740] Thu, 09 July 2020 17:02 Go to next message
I am supporting a system engineer to model the behavior of a sub-system and, while defining a scenario I came up to a problem which was: how to depict continuous and event-driven dynamics?
The Architecture diagram is not enough since it is static and the event-driven part is not explicit.
In the Sequence diagram (Exchange Scenario) I only found the pattern below to model this behavior. My question is, is this good? Do you have any better ideas to depict this information?
index.php/fa/38540/0/
Re: Depiction of continuous flows [message #1829742 is a reply to message #1829740] Thu, 09 July 2020 20:24 Go to previous message
Hi Fabio,
Just a couple of comments, despite the fact that I do not know if this is the right way to model it:
- Your Sequence links (or your functional exchange) car carry exchange items that are of type "events"
- You may use functional chains as well to model similar behavior, as you can express both data flows and control flows with Functional chains (but I am not saying this is more appropriate for your case, bottom line is that Exchange Scenario will enable you to be more precise in terms of time sequence). More information on Functional Chains: https://www.youtube.com/watch?v=ZqvfSURUpIY
I hope this helps,
Stephane
Previous Topic:Why are functions not common across the ARCADIA levels?
Next Topic:Bi-directional Functional Exchanges
Current Time: Mon Jul 21 14:33:51 EDT 2025
Powered by FUDForum. Page generated in 0.06970 seconds
