Home » Modeling » Papyrus » MOKA can't execute with error log
MOKA can't execute with error log [message #1804250] Thu, 21 March 2019 05:03 Go to next message
Hi:
I'm using moka to execute a HELLO WORLD model, provided in https://wiki.eclipse.org/Papyrus/UserGuide/ModelExecution,and when i press "debug" button, it says "An unexcepted error occured and see the error log".
Here is the error log:
!ENTRY org.eclipse.papyrus.infra.core 4 0 2019-03-21 16:57:36.860
!MESSAGE Unexpected Error
!STACK 0
	at org.eclipse.papyrus.moka.fuml.Semantics.Loci.LociL1.ExecutionFactory.createExecution(ExecutionFactory.java:86)
	at org.eclipse.papyrus.moka.fuml.Semantics.CommonBehaviors.Communications.ClassifierBehaviorExecution.execute(ClassifierBehaviorExecution.java:60)
	at org.eclipse.papyrus.moka.async.fuml.Semantics.CommonBehaviors.Communications.AsyncObjectActivation.startBehavior(AsyncObjectActivation.java:231)
	at org.eclipse.papyrus.moka.async.fuml.Semantics.CommonBehaviors.Communications.AsyncObjectActivation.run(AsyncObjectActivation.java:104)
If anyone knows the reason please help me!
Thanks a lot
Re: MOKA can't execute with error log [message #1804306 is a reply to message #1804250] Fri, 22 March 2019 02:41 Go to previous messageGo to next message
I have solved the problem, that's because I didn't set ClassifierBehavior for the Class.
Re: MOKA can't execute with error log [message #1829635 is a reply to message #1804306] Wed, 08 July 2020 01:56 Go to previous message
I also encountered the same problem,Could you give me some questions
Previous Topic:State machine diagram
Next Topic:Please ignore
Current Time: Sun Jul 20 22:08:56 EDT 2025
Powered by FUDForum. Page generated in 0.05255 seconds
