Home » Eclipse Projects » Sirius » Representations.aird - programmatically add model to Project Dependencies(Representations.aird - programmatically add model to Project Dependencies)
Representations.aird - programmatically add model to Project Dependencies [message #1829618] Tue, 07 July 2020 12:32 Go to next message
Hello :),
I am relatively new to Sirius and I want to programmatically add a model of a different Modeling Project to the Project Dependencies of another projects representations.aird file.
Manually I am able to do this (see image) but I would like to programmatically set this dependency within an External Java Action.
I would be very grateful for any help!
Kind regards,
Cynthia Diedrich
[Updated on: Tue, 07 July 2020 17:43] by Moderator
Re: Representations.aird - programmatically add model to Project Dependencies [message #1829678 is a reply to message #1829618] Wed, 08 July 2020 11:07 Go to previous messageGo to next message
Hi Cynthia,
The code of the corresponding action is here: AddModelDependencyAction. This action uses AddSemanticResourceCommand through SemanticResourceAdditionOperation.
A code like below should do the job:
org.eclipse.sirius.business.api.session.Session session = ...;
org.eclipse.emf.common.util.URI semanticResourcesURI = ...;
session.getTransactionalEditingDomain().getCommandStack().execute(new AddSemanticResourceCommand(session, semanticResourcesURI, new NullProgressMonitor()));
Laurent
Re: Representations.aird - programmatically add model to Project Dependencies [message #1829704 is a reply to message #1829678] Thu, 09 July 2020 04:28 Go to previous message
Hi Laurent,
Thank you for your quick answer, it worked!
Cynthia
Previous Topic:[SiriusCon 2020] Relive the conference: get access to the slides and videos
Next Topic:Grayed diagram name when reopening aird
Current Time: Mon Jul 21 07:08:06 EDT 2025
Powered by FUDForum. Page generated in 0.06646 seconds
