Errors : Software being installed: artificial_root 1.0.0.v1594017162698 [message #1829522] |
Mon, 06 July 2020 02:56  |
Hello.
I'm trying to use Eclipse installer and I get errors for multiple projects.
Below some errors:
ERROR: org.eclipse.equinox.p2.director code=10053 Cannot complete the install because one or more required items could not be found.
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:280)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.resolve(ProfileTransactionImpl.java:427)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:339)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:882)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3827)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3755)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3736)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3629)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:585)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:714)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: artificial_root 1.0.0.v1594017162698
ERROR: org.eclipse.equinox.p2.director code=0 Missing requirement: JBoss AS, WildFly & EAP Server Tools - Remote Systems Integration 3.2.4.v20170329-2126 (org.jboss.ide.eclipse.as.server.rse.integration.feature.feature.group 3.2.4.v20170329-2126) requires 'org.eclipse.equinox.p2.iu; org.eclipse.rse.subsystems.terminals.ssh 0.0.0' but it could not be found
ERROR: org.eclipse.equinox.p2.director code=1 Cannot satisfy dependency:
ERROR: org.eclipse.equinox.p2.director code=0 From: artificial_root 1.0.0.v1594017162698
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.jboss.ide.eclipse.as.server.rse.integration.feature.feature.group 0.0.0
Also on this project who worked on the middle of june and I didn't make any changes till now, I get the partially the same error:
ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: artificial_root 1.0.0.v1594018452864
ERROR: org.eclipse.equinox.p2.director code=0 Missing requirement: artificial_root 1.0.0.v1594018452864 requires 'org.eclipse.equinox.p2.iu; com.sap.ndb.studio.admin.feature.devedition.feature.group 0.0.0' but it could not be found
I'm using Installer version: 1.17.0 Build 4683.
Can you help me with this ?
FUDForum. Page generated in 0.04068 seconds
