Home » Newcomers » Newcomers » Error installing Eclipse(I get an error before the installation is completed)
Error installing Eclipse [message #1829462] Sat, 04 July 2020 00:49 Go to next message
I seem to get the following error before Eclipse finished installing, I have installed the lates java platform but I still get the error.
I have Mac computer running the latest O/S Catalina 10.15.5, It could be a very simple fix, however I am going around in circles trying to solve this problem.
I appreciate any help, Thank you
Re: Error installing Eclipse [message #1829465 is a reply to message #1829462] Sat, 04 July 2020 01:50 Go to previous messageGo to next message
Did you install a Java JDK as opposed to a JRE? Did you install this?
http://jdk.java.net/14/
I know there were some problems with some JDK like this one:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=559482
You can also try to download a package from here:
But it's highly likely that it will fail to launch the same way and for the same reason...
Re: Error installing Eclipse [message #1829467 is a reply to message #1829465] Sat, 04 July 2020 05:48 Go to previous messageGo to next message
Thank you Ed for the info, unfortunately I tried all of the above without success, so I don't know what else to do to instal this software that I was using before without any problems. I just hope to get some resolution.
Re: Error installing Eclipse [message #1829473 is a reply to message #1829467] Sat, 04 July 2020 09:41 Go to previous messageGo to next message
Which JDK exactly did you install? I.e., where did you get it from?
I believe the launcher uses this command to find the Java implementations on your machine:
/usr/libexec/java_home -X
What does that print?
Re: Error installing Eclipse [message #1829491 is a reply to message #1829473] Sun, 05 July 2020 02:35 Go to previous messageGo to next message
Hi Ed, thank you for your reply, I have run the line that you posted and this is the result
Davids-Mac-mini:~ david$ /usr/libexec/java_home -X
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<array>
<dict>
<key>JVMArch</key>
<string>x86_64</string>
<key>JVMBlacklisted</key>
<false/>
<key>JVMBundleID</key>
<string>com.oracle.java.14.jdk</string>
<key>JVMEnabled</key>
<true/>
<key>JVMHomePath</key>
<string>/Library/Java/JavaVirtualMachines/jdk-14.jdk/Contents/Home</string>
<key>JVMIsBuiltIn</key>
<false/>
<key>JVMName</key>
<string>Java SE 14</string>
<key>JVMPlatformVersion</key>
<string>14.0</string>
<key>JVMVendor</key>
<string>Oracle Corporation</string>
<key>JVMVersion</key>
<string>14</string>
</dict>
</array>
</plist>
I have been wondering if the latest version of Eclipse runs on Mac OS Catalina. I haven't found where this information could be.
Thanks once again
David
Re: Error installing Eclipse [message #1829516 is a reply to message #1829491] Mon, 06 July 2020 01:17 Go to previous messageGo to next message
It seems to me that Oracle published a 14.0.1 build. Perhaps installing that will help. Otherwise, I don't have a clue. Sorry.
Re: Error installing Eclipse [message #1829526 is a reply to message #1829516] Mon, 06 July 2020 03:45 Go to previous message
Thank you Ed, I will give Oracle a try and see what happens. I will keep trying. Cheers
Previous Topic:ISO C++ 2020 syntax fails to parse correctly
Next Topic:Garbled characters in Eclipse/Spring Tool Suite UI
Current Time: Mon Jul 21 11:38:22 EDT 2025
Powered by FUDForum. Page generated in 0.12408 seconds
