Home » Modeling » TMF (Xtext) » Providing quick fixes when IMarker are not created using Xtext's API
Providing quick fixes when IMarker are not created using Xtext's API [message #1829410] Thu, 02 July 2020 18:13 Go to next message
I have a DSL which is validaded through a custom AbstractDeclarativeValidator. The editor shows error markers and I now wish to provide quick fixes.
Currently the markers are not created through the warning and error methods but "manually" through IFile::createMarker (the main reason is basically that the AST is transformed multiple times and we do not have the original EObjects/EStructuralFeature at the end). The issue is that I don't manage to make the editor aware of my quick fixes (i.e. no little bulb on which we could click).
My first try to solve the issue:
  1. Declare a custom marker type through the org.eclipse.core.resources.markers extension point
  2. Declare a custom quick fix provider through the org.eclipse.ui.ide.markerResolution extension point
Result: the Problems view shows that quick fixes are available and allows me to select one however the editor only shows the warning/error icons.
Second try:
  1. Extend DefaultQuickfixProvider to provide the quick fixes
  2. Create the Marker with some attributes I've found after digging into Xtext's source code:
    val marker = file.createMarker(MyMarkers.MY_WARNING) // also tried MarkerTypes.NORMAL_VALIDATION here
    marker.setAttribute(IMarker.MESSAGE, "My warning message")
    marker.setAttribute(IMarker.SEVERITY, IMarker.SEVERITY_WARNING)
    marker.setAttribute(IMarker.CHAR_START, 0)
    marker.setAttribute(IMarker.CHAR_END, 0)
    marker.setAttribute(Issue.CODE_KEY, MyMarkers.MY_WARNING)
    marker.setAttribute(Issue.COLUMN_KEY, 0)
    marker.setAttribute(Issue.URI_KEY, URI.createPlatformResourceURI(file.fullPath.toString, true).toString)
    marker.setAttribute(IMarker.LINE_NUMBER, 0)
    marker.setAttribute(IMarker.LOCATION, "line: " + 0 + " " + file.fullPath.toString())
    marker.setAttribute("FIXABLE_KEY", true);
Result: the quick fix is shown in the editor and can be triggered but only when the editor has just been created. If I type anything the validator is called again and the bare warning/error icons are shown again: quick fixes are not available anymore. If I close the editor then open it again then the quick fix is shown as expected, until I type something.
I can only guess that some internal state is not set up properly and that my quick fixes are somehow discarded on refresh.
Third try:
  1. An old bug talks about the IResourceUIValidatorExtension interface which looks very promising. This interface is still available in Xtext's source code but I can't make it work. I tried:
    • To create a bindIResourceUIValidatorExtension() method in MyDslUiModule
    • To make my validator extend the interface
    • To add breakpoints everywhere in MarkerUpdaterImpl
  2. I searched for a relevant extension point but found nothing
Result: nothing happens, the methods/classes don't seem to be used anymore.
I'm running out of new ideas so would anyone have any advise to help me solve the issue?
Many thanks,
Emmanuel
Re: Providing quick fixes when IMarker are not created using Xtext's API [message #1829454 is a reply to message #1829410] Fri, 03 July 2020 17:58 Go to previous message
After some time spent debugging I kind of "solved" the issue.
When the editor is opened, Xtext calls
iFile.findMarkers(IMarker.MARKER, true, IResource.DEPTH_ZERO)
to discover the markers, which works pretty well. However, I noticed that the marker is updated when I call
in my validator. At this point the CODE_KEY attribute is not set (it is used to identify the fix) and thus Xtext cannot know there's a quick fix available. Not sure to understand what's going on exactly but putting this line at the end, i.e. after:
solved the issue.
Not sure it will work with multiple markers but the issue doesn't look related to Xtext anyway. I may post in the Platform forum if I face further issues.
Previous Topic:Getting user types ID
Next Topic:Error in running workflow
Current Time: Mon Jul 28 17:50:02 EDT 2025
Powered by FUDForum. Page generated in 0.24650 seconds
