Home » Eclipse Projects » Oomph » Targlets and dynamic update site URIs
Targlets and dynamic update site URIs [message #1829299] Wed, 01 July 2020 03:58 Go to next message
In the Capella oomph model, I have to reference development build update sites for sirius. Those sites change quite often and the sirius team deletes older snapshots regularly.
I then come up with Oomph installation errors such as:
ERROR: org.eclipse.equinox.p2.metadata.repository code=1000 No repository found at https://download.eclipse.org/sirius/updates/stable/6.3.1-S20200506-133541/2019-06/.
Especially when I bootstrap a new installation, such an error is not very sexy for users. Do you know if there is any way to tell the engine to just warn about such a case rather than to report an error and bail out?
Re: Targlets and dynamic update site URIs [message #1829301 is a reply to message #1829299] Wed, 01 July 2020 04:12 Go to previous messageGo to next message
No, failure to load root repos causes overall failure. I suppose Oomph could try to hack that behavior to be different, but presumably you list the site because it's needed to resolve requirements and if it's missing (fails to load) those requirements will not resolve...
You should ask those folks to provide composites that are stable. E.g., like EMF does:
https://download.eclipse.org/modeling/emf/emf/builds/index.html
E.g.,
http://download.eclipse.org/modeling/emf/emf/builds/release/latest
http://download.eclipse.org/modeling/emf/emf/builds/milestone/latest
http://download.eclipse.org/modeling/emf/emf/builds/nightly/latest
Or use a composite such as the following which get updated by their contributions when their SimRel contribution changes and at milestones:
https://download.eclipse.org/staging/2020-09/
https://download.eclipse.org/releases/2020-09/
Re: Targlets and dynamic update site URIs [message #1829303 is a reply to message #1829301] Wed, 01 July 2020 04:34 Go to previous messageGo to next message
I guess it would still work because I use the "include all requirements = false" trick. But yes, maybe it's better to fail with a clear error instead of standing there with compiler errors, not knowing what's going on.. I asked them before to make composites, apparently it's too much work. I might look at how EMF does it and propose them some patches.
Thank you Ed.
Re: Targlets and dynamic update site URIs [message #1829304 is a reply to message #1829303] Wed, 01 July 2020 05:03 Go to previous messageGo to next message
EMF uses a rather complex approach, but given I'm the release engineer, I wanted something that is completely automated, and not glued together with horrible shell scripts. So it's completely written in Java using p2 APIs.
https://git.eclipse.org/c/emf/org.eclipse.emf.git/tree/releng/org.eclipse.emf.releng/src/org/eclipse/emf/releng/UpdateSiteGeneratorTest.java
It maintains the entire structure, including generating the HTML, and does handy things like deleting milestones for older releases automatically when a milestone for a new release is published. So I never need to touch anything manually ever.
For JustJ I generalized the implementation:
https://git.eclipse.org/c/justj/justj.tools.git/tree/plugins/org.eclipse.justj.p2
To produce sites like this:
https://download.eclipse.org/justj/sandbox/jres/14/updates/
No milestones or releases yet...
This implementation is reusable and can be used like this:
https://git.eclipse.org/c/justj/justj.tools.git/tree/releng/org.eclipse.justj.tools.parent/promotion/pom.xml#n73
It promotes the repo produced by the build to the project's downloads
Re: Targlets and dynamic update site URIs [message #1829367 is a reply to message #1829304] Thu, 02 July 2020 03:30 Go to previous message
Never touching manually sounds very nice . Ours is a mess... Thank you for the pointers.
Previous Topic:Java Main/Test sources working set
Next Topic:Errors : Software being installed: artificial_root 1.0.0.v1594017162698
Current Time: Mon Jul 21 07:41:44 EDT 2025
Powered by FUDForum. Page generated in 0.06242 seconds
