Home » Eclipse Projects » Standard Widget Toolkit (SWT) » What are the minimum requirements of SWT (OSX)
What are the minimum requirements of SWT (OSX) [message #1829102] Thu, 25 June 2020 03:58 Go to next message
A customer is trying our eclipse on an older OSX version (10.8.5)
but he gets:
Application error!STACK 1org.eclipse.swt.SWTError: Not implemented at org.eclipse.swt.SWT.error(SWT.java:4746) at org.eclipse.swt.SWT.error(SWT.java:4635) at org.eclipse.swt.SWT.error(SWT.java:4606) at org.eclipse.swt.widgets.Display.error(Display.java:1112) at org.eclipse.swt.widgets.Display.createDisplay(Display.java:846) at org.eclipse.swt.widgets.Display.create(Display.java:837) at org.eclipse.swt.graphics.Device.<init>(Device.java:132) at org.eclipse.swt.widgets.Display.<init>(Display.java:736) at org.eclipse.swt.widgets.Display.<init>(Display.java:727) at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:778) at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:166) at org.eclipse.ui.internal.ide.application.IDEApplication.createDisplay(IDEApplication.java:180) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594) at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
googling this doesn't give me much (or very old results)
Also it doesn't say what is not implemented..
So i wonder what are the minimum requirements for SWT on OSX?
I guess it must be 64 bit, but as far as i know 10.8 is 64 bits and it seems to start in 64 bit mode.
Re: What are the minimum requirements of SWT (OSX) [message #1829115 is a reply to message #1829102] Thu, 25 June 2020 07:18 Go to previous messageGo to next message
Wow 10.8 was released 7 years ago and received its last update 4 years ago.
You didn't say what version of the platform you ship on. The list of supported operating systems is listed in each release's release notes, which links to the release plan's "Target Environments" section of the Eclipse project plan. For example, here are the release notes and plan for 4.13:
https://www.eclipse.org/eclipse/development/readme_eclipse_4.13.php
https://www.eclipse.org/projects/project-plan.php?planurl=http://www.eclipse.org/eclipse/development/plans/eclipse_project_plan_4_13.xml#target_environments
Re: What are the minimum requirements of SWT (OSX) [message #1829117 is a reply to message #1829115] Thu, 25 June 2020 07:39 Go to previous message
right that was what i was searching for a bit
I know it is old, but i just wanted to have some documentation where i could find such a thing.
But it is very hard to find for example:
https://www.eclipse.org/downloads/
go from there.. where is the OS requirement?
the only thing you can find if you really click around from there is:
https://wiki.eclipse.org/Eclipse/Installation#Eclipse_4.15_.282020-03.29
but that only mentions that java 8 is required.
Problem is that SWT has a lot more stuff (windows mostly works) but it seems that mac and i guess also Linux (gtk version?) are also a big factor.
Previous Topic:Code signature error: could not load SWT library in OS X Catalina
Next Topic:ARM port
Current Time: Sun Aug 31 05:20:43 EDT 2025
Powered by FUDForum. Page generated in 0.02597 seconds
