Home » Eclipse Projects » Eclipse Platform » "Login Required" when trying to update Eclipse(Requesting Username and Password)
"Login Required" when trying to update Eclipse [message #489217] Thu, 01 October 2009 17:55 Go to next message
I am running Eclipse Galileo 3.5 and SR1.
Both versions update fine when I perform a software update or test connection via the preferences window.
Unfortunately, my coworker is prompted for a username and password when he does the update/test connection. He is prompted for every single site in the default list of locations.
I don't know why it works on my box but not his. We both authenticated the firewall and the Network Connection is set to "Direct"
Please provide any assistance.
Windows XP2
[Updated on: Thu, 01 October 2009 17:57] by Moderator
Re: "Login Required" when trying to update Eclipse [message #489345 is a reply to message #489217] Fri, 02 October 2009 10:16 Go to previous messageGo to next message
If you have done Test Connection on a site that definitely does not require authentication, then the login prompt is a red herring, and you should continue to explore other avenues of network disruption.
What happens if he tries to pull up one of those sites in a browser?
Re: "Login Required" when trying to update Eclipse [message #489349 is a reply to message #489345] Fri, 02 October 2009 10:41 Go to previous messageGo to next message
I hit the Galileo update link "http://download.eclipse.org/releases/galileo" using a web browser and it displayed the web page with the plugins just fine.
[Updated on: Fri, 02 October 2009 10:44] by Moderator
Re: "Login Required" when trying to update Eclipse [message #489353 is a reply to message #489217] Fri, 02 October 2009 10:55 Go to previous messageGo to next message
Anything in the Error Log view? Window-> Show View...
Re: "Login Required" when trying to update Eclipse [message #489371 is a reply to message #489353] Fri, 02 October 2009 12:06 Go to previous messageGo to next message
If I do a "Check For Updates" from the Help menu, it will prompt me for username/password for each of the listed locations.
In the Error Log View, it just displays the error message:
"Unable to load the repository http://download.eclipse.org/releases/galileo"
- "Authentication failed..."
This is repeated for each site. I had to cancel the login prompts which probably caused the authentication failures.
Re: "Login Required" when trying to update Eclipse [message #489373 is a reply to message #489217] Fri, 02 October 2009 12:15 Go to previous messageGo to next message
Is there a stack trace on either of those errors?
If you double click it in the error log view you would see it.
If I intentionally cancel login to an HTTPS site, I see an exception on the "Unable to load repository" error log entry.
Stacktrace might help track it down further..
Re: "Login Required" when trying to update Eclipse [message #489374 is a reply to message #489371] Fri, 02 October 2009 12:20 Go to previous messageGo to next message
Another thing you could do is download wget (http://gnuwin32.sourceforge.net/downlinks/wget.php) which is a command line utility to retrieve remote files.
Then try,
wget http://download.eclipse.org/releases/galileo/content.jar
To see if you get any HTTP errors.
Re: "Login Required" when trying to update Eclipse [message #495144 is a reply to message #489217] Tue, 03 November 2009 17:02 Go to previous messageGo to next message
I am experiencing the problem as well. Here is event log
eclipse.buildId=M20090917-0800
java.version=1.6.0_16
Framework arguments: -product org.eclipse.epp.package.reporting.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.reporting.product
Error
Tue Nov 03 15:50:43 CST 2009
org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception: Authentication failed for http://download.eclipse.org/releases/galileo.
at org.eclipse.equinox.internal.p2.metadata.repository.CacheMan ager.createCache(CacheManager.java:128)
at org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleM etadataRepositoryFactory.java:60)
at org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.validateAndLoad(Simp leMetadataRepositoryFactory.java:99)
at org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.load(SimpleMetadataR epositoryFactory.java:87)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.factoryLoad(MetadataRepositoryManager.java :54)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:669)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:617)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:92)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:88)
at org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.loadMetadataRepository(ProvisioningUtil.java: 88)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableMeta dataRepositoryManager.doLoadRepository(QueryableMetadataRepo sitoryManager.java:55)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadRepository(QueryableRepositoryManager.java :195)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadAll(QueryableRepositoryManager.java:108)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryH andler$2.run(PreloadingRepositoryHandler.java:71)
Re: "Login Required" when trying to update Eclipse [message #500767 is a reply to message #495144] Sat, 28 November 2009 06:55 Go to previous messageGo to next message
I too am seeing this error
java.version=1.6.0_15
Related links:
http://dev.eclipse.org/newslists/news.eclipse.newcomer/msg28 963.html
Re: "Login Required" when trying to update Eclipse [message #500769 is a reply to message #500767] Sat, 28 November 2009 06:58 Go to previous messageGo to next message
I can download the jar file via http without difficulty.
[Updated on: Sat, 28 November 2009 07:06] by Moderator
Re: "Login Required" when trying to update Eclipse [message #500773 is a reply to message #489217] Sat, 28 November 2009 09:16 Go to previous messageGo to next message
If it's an easily repeatable scenario, you may want to open a bug.
https://bugs.eclipse.org/bugs/enter_bug.cgi
RT -> Equinox -> p2.
Re: "Login Required" when trying to update Eclipse [message #500804 is a reply to message #489217] Sat, 28 November 2009 17:41 Go to previous messageGo to next message
I had to switch between Native and Direct connection in the preferences to overcome the error.
Re: "Login Required" when trying to update Eclipse [message #743581 is a reply to message #489217] Fri, 21 October 2011 11:38 Go to previous messageGo to next message
Switching to "Direct" under "Window->Preferences->General->Network Connection" worked for me as well.
Re: "Login Required" when trying to update Eclipse [message #1829090 is a reply to message #489371] Thu, 25 June 2020 01:42 Go to previous messageGo to next message
This must be an issue with how your network is configured. Are you behind a proxy that requires authentication? The repository itself definitely does not require authentication. And of course Galileo is extremely old, so even if there is a bug in p2's Galileo version it would be fixed only in a new release, i.e., one from here:
https://www.eclipse.org/downloads/
Re: "Login Required" when trying to update Eclipse [message #1832991 is a reply to message #489374] Wed, 30 September 2020 08:28 Go to previous messageGo to next message
I cannot download it from the link that you indicated.
Please check it out.
Re: "Login Required" when trying to update Eclipse [message #1833199 is a reply to message #1832991] Tue, 06 October 2020 08:40 Go to previous message
You're going to have to elaborate on that.
Previous Topic:Eclipse IDE, project context menu - move the Close option far far away from Refresh
Next Topic:Searching for Help in replacing actionSet with Commands/Menu
Current Time: Sun Jul 20 21:03:10 EDT 2025
Powered by FUDForum. Page generated in 0.06009 seconds
