Home » Eclipse Projects » Paho » Paho-MQTT is not able to connect more than 339 connections(Number of paho-mqtt connections is not growing beyond 339 connections)
Paho-MQTT is not able to connect more than 339 connections [message #1826655] Tue, 28 April 2020 07:36 Go to next message
I am using paho-mqtt. The max number of paho mqtt connections that I can make successfully through python code is 339. Beyond 339 connections, mqtt is failing. Could you pls help me to fix this issue. I am using Ubuntu 18 on Amazon 4.15.0-1065-aws.
Re: Paho-MQTT is not able to connect more than 339 connections [message #1829064 is a reply to message #1826655] Wed, 24 June 2020 09:29 Go to previous message
Reproduce with some minimal code, less than 100 lines.
Show us your code, we might be able to decipher.
Previous Topic:MQTT Client connect fails
Next Topic:New Service Release of Paho MQTT Java Client library
Current Time: Mon Jul 21 05:12:49 EDT 2025
Powered by FUDForum. Page generated in 0.06518 seconds
