Home » Eclipse Projects » Sirius » How to accelerate opening editors using DialectUIManager?(DialectUIManager)
How to accelerate opening editors using DialectUIManager? [message #1829031] Wed, 24 June 2020 04:10 Go to next message
I am working on building an Eclipse RCP application with Sirius. Currently I ran into a performance problem: I need to open diagrams, tables, ... and other Sirius representations. I searched in the forum and found that I can use DialectUIManager to do that work.
The code snippet is:
DialectUIManager.INSTANCE.openEditor(mySession, myDiagram,
myProgressMonitor);
The problem is that, I found that using this code snippet to open representation editors is extremely slow. I used JProfiler to analyze the application, and the openEditor method is just taking a lot of time. That's sort of annoying and brings a bad experience to my application.
So I wonder if there is any way to improve the performance of the DialectUIManager.openEditor method? Or is there any alternatives? Or why this method takes so much time?
Thanks so much for any help.
Re: How to accelerate opening editors using DialectUIManager? [message #1829038 is a reply to message #1829031] Wed, 24 June 2020 04:46 Go to previous messageGo to next message
This is the normal entry point to open a representation. If it is slow in your context, the cause is not this method in particular. It really depends on what you consider "too slow", what is the size of your model, of your diagrams, the complexity of you odesign, etc.
You can try to disable the "Do refresh on representation opening" preference (in the main "Sirius" preference page). This will open your representations as fast as Sirius can, but with the risk that what you seen on screen in not in synch with the current state of your model.
Pierre-Charles
Re: How to accelerate opening editors using DialectUIManager? [message #1829051 is a reply to message #1829038] Wed, 24 June 2020 06:52 Go to previous messageGo to next message
It normally uses 2-3 second to open an editor every time I start my application, it's quite slow compared to other methods. Thanks for your advice and I'll try to optimize my model and representation design.
Re: How to accelerate opening editors using DialectUIManager? [message #1829058 is a reply to message #1829051] Wed, 24 June 2020 08:44 Go to previous messageGo to next message
Yufei Zhou wrote on Wed, 24 June 2020 12:52
If the slowness is only the first few times you open a diagram right after application startup, it could be caused by lazy loading/initialization of Eclipse plug-ins, and/or JVM warmup.
You mention "compared to other methods": which other methods give faster results?
Re: How to accelerate opening editors using DialectUIManager? [message #1829059 is a reply to message #1829051] Wed, 24 June 2020 08:47 Go to previous messageGo to next message
You need to distinguish between opening a first editor which will incur substantial JVM warm up overheads and opening a 100th editor by which time the JVM should have loaded all the classes and optimized the reptitious code.
Sirius is a big application so there is a lot to warm up. However you should check that you aren't warming up other applications too, particularly Xtext or UML or other Sirius editors that may not necessary at least for your initial view. You might also check that Forms/Property support is not loaded till needed.
If your Sirius editor is critical to your RCP user's experience you could arrange to load and optimize many relevant classes via earlyStartup. Not a recommended approach since all other usages are penalized by an optimization for one.
Ed Willink
Open your editor, then look at the configuration in Help About to see what has actually been started and compare it with a raw configuration before opening your editor.
Re: How to accelerate opening editors using DialectUIManager? [message #1829215 is a reply to message #1829058] Sun, 28 June 2020 06:52 Go to previous messageGo to next message
Thanks for your help. By mentioning "compared to other methods" that I mean my own rcp plugin codes, which doesn't rely on Sirius. So I think the problem is caused by Sirius's lazy-activation policy, and I'm trying to solve it by loading Sirius plugin when my rcp application starts.
But the problem is I cannot find how to load Sirius eagerly when the application starts. Would you please tell me how can I do that work? I think that will accelerate all the Sirius apis at the first startup and solves my problem.
Re: How to accelerate opening editors using DialectUIManager? [message #1829216 is a reply to message #1829215] Sun, 28 June 2020 08:32 Go to previous message
If you are really sure that you want all users to take the start up hit of early starting Sirius, just reference a class from each interesting Sirius plugin and invoke as InterestingSiriusClass.class.getName() or similar from your own early startup code.
If you have other users you might find that just starting a worker thread early which early starts one Sirius plugin per second in the background might be a compromise.
Ed Willink
[Updated on: Sun, 28 June 2020 15:33] by Moderator
Previous Topic:Synchronizing Sirius with Xtext
Next Topic:StateMachine - Transitions
Current Time: Mon Jul 21 09:11:25 EDT 2025
Powered by FUDForum. Page generated in 0.08728 seconds
