Widget: Text [message #1828669] |
Tue, 16 June 2020 06:03  |
I would like to work more with the "open Dialog" in a Table representation.
Specially with the widget "Text". Therefor I want to use the value that I enter in the TextBox, to set the value of a certain cell into my own variable LinkedHashMap<String, String> using method which I made in service class.
As off now I knew that (The value entered in the text widget is set in a variable "newValue". Therefore under the "Change Context" operation, we need to add a set operation where value expression is "newValue".)
But My Problem is, how can we get the changes value which I enter in the text into my own variable that I created in service "LinkedHashMap<String, String>". I am not able to save
I would like to have something like: I am able to fetch the value from Map through method call and show in text but, when I'm changing in text then I want to save into same place in same Map.
FUDForum. Page generated in 0.05603 seconds
