Home » Newcomers » Newcomers » .log error (error in eclipse 2020-03 and in 06)
.log error [message #1828960] Tue, 23 June 2020 04:57 Go to next message
After downloading general-purpose tool and web, XML tools my Eclipse doesn't work it says there is an error in .log file
I installed 3-4 ties again and again the same error is there.
Then I download Eclipse 2020-06 version then I am not able to download general-purpose and web, XML tools.
What should I do?
Re: .log error [message #1828967 is a reply to message #1828960] Tue, 23 June 2020 08:06 Go to previous messageGo to next message
What are the contents of the .log file it mentioned to look at? And if you can, take screenshots using your operating system's native support.
Re: .log error [message #1828992 is a reply to message #1828960] Tue, 23 June 2020 13:24 Go to previous message
!ENTRY org.eclipse.osgi 4 0 2020-06-23 22:51:23.656
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1093)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1049)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:658)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
Previous Topic:Missing plugins when upgrading Eclipse
Next Topic:License management strategy and eclipse platform support for the same
Current Time: Fri Sep 26 07:41:44 EDT 2025
Powered by FUDForum. Page generated in 0.09008 seconds
