Home » Modeling » GMF (Graphical Modeling Framework) » polyline color doesn't change after moving figure to seperate plug-in
polyline color doesn't change after moving figure to seperate plug-in [message #182617] Fri, 11 April 2008 09:36 Go to next message
Originally posted by: nico.lammers.gmail.com
Hi all,
Subject says all I guess.
When I have the Figure as an inner class in the EditPart, the line color
changes to whatever you've set in the graphical definition.
Now I'm basically using a custom figure (I extracted my figures to a
seperate plugin) and, while the code is the same as when using the
Figure inner class, the color of the link won't change anymore...
Does anyone have any experiences with this?
~ Nico Lammers
Re: polyline color doesn't change after moving figure to seperate plug-in [message #182704 is a reply to message #182617] Fri, 11 April 2008 14:38 Go to previous messageGo to next message
Hello Nico,
Try debugging ConnectionEditPart.refreshForegroundColor().
Alex Shatalin
Re: polyline color doesn't change after moving figure to seperate plug-in [message #182839 is a reply to message #182704] Mon, 14 April 2008 04:46 Go to previous messageGo to next message
Okay.. I would do that if I knew how ;) I installed the SDK, but Eclipse
won't show me the code for Connection(Node)EditPart...
Some Eclipse-noobishness here.. :(
Alex Shatalin wrote:
> Hello Nico,
> Alex Shatalin
Re: polyline color doesn't change after moving figure to seperateplug-in [message #182862 is a reply to message #182839] Mon, 14 April 2008 06:12 Go to previous messageGo to next message
Hello Nico,
> Eclipse won't show me the code for Connection(Node)EditPart...
This should be one of the super-classes of EditPart generated for the connection
in your diagram.
Alex Shatalin
Re: polyline color doesn't change after moving figure to seperateplug-in [message #182894 is a reply to message #182862] Mon, 14 April 2008 07:12 Go to previous message
I know.. but I mean that while debugging it doesn't show the code of the
runtime classes because there is no source code available.. I though
installing the GMF source/SDK would solve this, but apparently I'm
missing something .. don't know how to explain otherwise :(
~ Nico Lammers
> Hello Nico,
> connection in your diagram.
> Alex Shatalin
Previous Topic:The need for Compartments
Next Topic:Compartment in diagram
Current Time: Tue Jul 22 22:24:17 EDT 2025
Powered by FUDForum. Page generated in 0.25665 seconds
