Is TLS certificate on marketplace site used by 2020-06 self-signed? [message #1828799] |
Fri, 19 June 2020 00:24 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
David M. Karr![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=davidmichaelkarr%40gmail.com) Messages: 807 Registered: July 2009 |
Before today, I was using Eclipse 2020-03.
Our firewall blocks TLS connections to servers that use self-signed certificates. There are at least two Eclipse plugins that I use that have update sites using self-signed certificates. When I want to check for updates to those plugins, I have to disconnect from VPN, change the Eclipse Network Connections settings, and then update.
Today I installed 2020-06.
Now, when I even attempt to bring up the marketplace client dialog, I get TLS connection errors. I would have to assume that 2020-06 is connecting to a different marketplace site than 2020-03, but that seems a little odd.
I will attempt to disconnect from VPN and see whether that fixes the marketplace client.
I confirm that it does.
[Updated on: Fri, 19 June 2020 05:29] Report message to a moderator
FUDForum. Page generated in 0.03508 seconds
