Home » Eclipse Projects » EGit / JGit » Cannot Open Compare Editor - This is a merge commit with more than one ancestor
Cannot Open Compare Editor - This is a merge commit with more than one ancestor [message #1828789] Thu, 18 June 2020 10:42 Go to next message
This error screen popup when comparing with previous version.
error screen title : Cannot Open Compare Editor
error screen message : This is a merge commit with more than one ancestor
How to solve this issue?
Thanks.
Re: Cannot Open Compare Editor - This is a merge commit with more than one ancestor [message #1828814 is a reply to message #1828789] Fri, 19 June 2020 03:04 Go to previous messageGo to next message
More details needed.
  • Which EGit version?
  • How exactly are you trying to open the compare editor? (Which menu, where (in the package explorer? in an editor? in the history view?), what's the current selection?)
Current HEAD in your git repository seems to be at a merge commit.
In general, EGit cannot show the compare editor in this case since it doesn't know against which parent commit you want to compare. In some cases we might add something to let the user choose the parent commit to compare against, which is why I'd like to know what exactly you're doing.
A possible work-around with EGit 5.8.0 might be to select the merge commit and the parent commit wanted in the history view, then use "Show Unified Diff" from the context menu. To see a side-by-side diff of one file, use the link available on a hunk header (on the numbers in the @@ lines).
Re: Cannot Open Compare Editor - This is a merge commit with more than one ancestor [message #1828834 is a reply to message #1828814] Fri, 19 June 2020 10:20 Go to previous messageGo to next message
version : m2e 1.9.1.20180912-1601 Eclipse Java EE IDE for Web Developers 2018-09 (4.9.0)
Steps to reproduce this error:
History View
Select any one file in a specific commit which is a merge commit with more than one ancestor.
Right click.
"Compare with Previous Version" option popup.
Click the "Compare with Previous Version" option.
[Updated on: Fri, 19 June 2020 10:26] by Moderator
Re: Cannot Open Compare Editor - This is a merge commit with more than one ancestor [message #1828838 is a reply to message #1828834] Fri, 19 June 2020 11:55 Go to previous messageGo to next message
We might indeed ask the user at that point which parent he wants to compare against. Please open an enhancement request at https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EGit .
Re: Cannot Open Compare Editor - This is a merge commit with more than one ancestor [message #1828854 is a reply to message #1828838] Fri, 19 June 2020 22:11 Go to previous message
I open:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=564493
Previous Topic:EGit signing somehow not accepted by GitLab, works fine for GitHub
Next Topic:Usage of ssh-agent
Current Time: Mon Jul 21 06:57:19 EDT 2025
Powered by FUDForum. Page generated in 0.29391 seconds
