NPE in Dialog Eclipse Installer Extentions [message #1828823] |
Fri, 19 June 2020 06:07  |
I create a own Setup Task. But now when I try to use it in a new Installation (other PC without any Eclipse) I get the following exeption.
!ENTRY org.eclipse.oomph.setup.installer 4 0 2020-06-19 12:02:09.051
!MESSAGE java.lang.NullPointerException
!STACK 0
at org.eclipse.oomph.setup.ui.EnablementComposite.enableButtons(EnablementComposite.java:393)
at org.eclipse.oomph.setup.ui.EnablementComposite.install(EnablementComposite.java:265)
at org.eclipse.oomph.setup.internal.installer.ExtensionPage.install(ExtensionPage.java:239)
at org.eclipse.oomph.setup.internal.installer.ExtensionPage$1.performFinish(ExtensionPage.java:98)
at org.eclipse.oomph.setup.ui.wizards.SetupWizard.performFinish(SetupWizard.java:697)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:832)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:472)
at org.eclipse.jface.dialogs.Dialog.lambda$0(Dialog.java:619)
at org.eclipse.swt.events.SelectionListener$1.widgetSelected(SelectionListener.java:84)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:252)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4213)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4030)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3630)
at org.eclipse.oomph.setup.internal.installer.Installer.runEventLoop(Installer.java:371)
at org.eclipse.oomph.setup.internal.installer.InstallerDialog.show(InstallerDialog.java:399)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.run(InstallerApplication.java:295)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.start(InstallerApplication.java:397)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
I checked that the repository URL ant the feature Name are correct.
How can I see if the Problem is within my Setup Task?
Frank
FUDForum. Page generated in 0.03044 seconds
