Home » Modeling » TMF (Xtext) » Code signature error: could not load SWT library in OS X Catalina
Code signature error: could not load SWT library in OS X Catalina [message #1828735] Wed, 17 June 2020 18:39 Go to next message
Hi everyone,
I am trying to run an Xtend IDE from Eclipse but after I click Run As -> Eclipse Application, Eclipse outputs the error below:
(simplified path for readability)
java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
	/Users/.../.../.cp/libswt-cocoa-4932r18.jnilib: dlopen(/Users/.../.../.cp/libswt-cocoa-4932r18.jnilib, 1): no suitable image found.  Did find:
	/Users/.../.../.cp/libswt-cocoa-4932r18.jnilib: code signature in (/Users/.../.../.cp/libswt-cocoa-4932r18.jnilib) not valid for use in process using Library Validation: mapping process and mapped file (non-platform) have different Team IDs
	/Users/.../.../.cp/libswt-cocoa-4932r18.jnilib: stat() failed with errno=316
	no swt-cocoa in java.library.path: [/Users/xxx/Library/Java/Extensions, /Library/Java/Extensions, /Network/Library/Java/Extensions, /System/Library/Java/Extensions, /usr/lib/java, .]
	/Users/shaokai/.swt/lib/macosx/x86_64/libswt-cocoa-4932r18.jnilib: dlopen(/Users/shaokai/.swt/lib/macosx/x86_64/libswt-cocoa-4932r18.jnilib, 1): no suitable image found.  Did find:
	/Users/shaokai/.swt/lib/macosx/x86_64/libswt-cocoa-4932r18.jnilib: code signature in (/Users/shaokai/.swt/lib/macosx/x86_64/libswt-cocoa-4932r18.jnilib) not valid for use in process using Library Validation: mapping process and mapped file (non-platform) have different Team IDs
	Can't load library: /Users/shaokai/.swt/lib/macosx/x86_64/libswt-cocoa.jnilib
	at org.eclipse.swt.internal.Library.loadLibrary(Library.java:342)
	at org.eclipse.swt.internal.Library.loadLibrary(Library.java:256)
	at org.eclipse.swt.internal.C.<clinit>(C.java:19)
	at org.eclipse.swt.widgets.Display.<clinit>(Display.java:107)
	at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:760)
	at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:166)
	at org.eclipse.ui.internal.ide.application.IDEApplication.createDisplay(IDEApplication.java:180)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:567)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
I suspect this is an OS X Catalina problem, as I've heard that it enforces a stricter requirement on code signatures in this new version.
Any thoughts on resolving this issue? Thanks very much.
Shaokai
Re: Code signature error: could not load SWT library in OS X Catalina [message #1828738 is a reply to message #1828735] Wed, 17 June 2020 19:43 Go to previous messageGo to next message
Have not seen this yet. Which eclipse version do you use and which target platform
Maybe there is also some outdated stuff in your .swt folder
[Updated on: Wed, 17 June 2020 19:46] by Moderator
Re: Code signature error: could not load SWT library in OS X Catalina [message #1828739 is a reply to message #1828738] Wed, 17 June 2020 19:51 Go to previous messageGo to next message
Maybe https://www.eclipse.org/forums/index.php/f/11/ is also a better place to ask
Re: Code signature error: could not load SWT library in OS X Catalina [message #1828743 is a reply to message #1828739] Wed, 17 June 2020 20:05 Go to previous message
Christian Dietrich wrote on Wed, 17 June 2020 23:51
Hi Christian,
Thanks for your quick reply. I am using Eclipse 2020-03 (4.15.0) and my platform is macOS Catalina (10.15.4).
My SWT library is libswt-cocoa-4932r18, which seems to be relatively recent.
I will also forward the topic to the location you suggested. Thanks.
Shaokai
Previous Topic:Content assist testing with 2 grammars
Next Topic:How should I write an Xtext rule that refers to itself?
Current Time: Sat Jul 26 20:43:27 EDT 2025
Powered by FUDForum. Page generated in 0.03437 seconds
