Home » Modeling » Papyrus » Older Papyrus Package download
Older Papyrus Package download [message #1828609] Mon, 15 June 2020 01:54 Go to next message
The Papyrus package download site (https://www.eclipse.org/papyrus/download.html) offers only the latest two released versions.
Where can I get Papyrus download packages (including eclipse) which are no longer listed in https://www.eclipse.org/papyrus/download.html?
E.g., I want to download the 2019-09 release (4.5.0).
Re: Older Papyrus Package download [message #1828615 is a reply to message #1828609] Mon, 15 June 2020 04:54 Go to previous messageGo to next message
The older releases are available on the site you mentioned as uptate sites.
For the previous RCP, you should be able to get them from this site :
Papyrus git repository
HTH.
Yoann.
Re: Older Papyrus Package download [message #1828625 is a reply to message #1828615] Mon, 15 June 2020 06:40 Go to previous messageGo to next message
Hi Bernd,
https://www.eclipse.org/papyrus/downloads/index.php
at least back to 3.0
/Carsten
Re: Older Papyrus Package download [message #1828628 is a reply to message #1828625] Mon, 15 June 2020 07:00 Go to previous messageGo to next message
Hallo Yoann, Carsten,
Thank you for the quick reply.
Your links point to the Papyrus only versions (around 95 MByte). I was looking for the Papyrus + Eclipse versions (around 600 MByte) as they are offered in https://www.eclipse.org/papyrus/download.html
Re: Older Papyrus Package download [message #1828629 is a reply to message #1828628] Mon, 15 June 2020 07:25 Go to previous messageGo to next message
Yes, these do. Please, get a matching Eclipse Modeling Tools edition via https://www.eclipse.org/downloads/packages/release first. Then install Papyrus as AddOn.
/Carsten
Re: Older Papyrus Package download [message #1828635 is a reply to message #1828629] Mon, 15 June 2020 09:27 Go to previous messageGo to next message
Hallo Carsten,
That's the issue; due to company firewall restrictions I cannot install any additional plugins into eclipse. I need both, eclipse and papyrus, in one zip-file which I then just extract and run.
Re: Older Papyrus Package download [message #1828638 is a reply to message #1828635] Mon, 15 June 2020 09:40 Go to previous messageGo to next message
Hi Bernd,
you also can install it on another machine with the same OS type/version/bitness and the same user name. Then zip the installation and the workspace directory. Unzip both at the same base directories on the target machine. This at least works for Windows and Linux Installations. The only thing missing is the launcher. But to add a launcher is trivial.
/pica
Re: Older Papyrus Package download [message #1828640 is a reply to message #1828638] Mon, 15 June 2020 09:59 Go to previous message
Hallo Carsten,
That's what I do.
I created this topic because I just wondered where the previous packages (eclipse + papyrus) once they disappear from the https://www.eclipse.org/papyrus/download.html site are stored. But it seems that they are deleted.
Thank you!
Previous Topic:Different size in diagram
Next Topic:Stereotype for Comment Link
Current Time: Mon Jul 21 06:14:59 EDT 2025
Powered by FUDForum. Page generated in 0.34235 seconds
