Home » Eclipse Projects » Eclipse Platform » Unable to install scala in eclipse oxygen version(Unable to install scala plugin in eclipse oxygen version)
Unable to install scala in eclipse oxygen version [message #1828616] Mon, 15 June 2020 05:37 Go to next message
Installed eclipse IDE in ubuntu 16.04 64-bit machine. Going ahead trying to install scala plugin in this. Unable to install it.
I followed below steps:
In eclipse go to Help->Install New Software->Added the link " http://download.scala-ide.org/sdk/lithium/e47/scala212/stable/site" in "Work with" dialog box. Select it and press Enter.
But I get an error stating :
HTTP Server 'Bad Gateway' : http://download.scala-ide.org/sdk/lithium/e47/scala212/stable/site/content.xml
HttpComponents connection error response code 502
and sometimes timeout error.
I even tried installing scala IDE 4.7.x from eclipseMarketplace and run into a similar error:
HTTP Server 'Bad Gateway' : http://download.scala-ide.org/sdk/lithium/e47/scala212/dev/site/content.xml
HttpComponents connection error response code 502.
and sometimes timeout errors as
Unable to read repository at http://download.scala-ide.org/sdk/lithium/e47/scala212/dev/site/content.xml.
Connect to download.scala-ide.org:80 timed out
Is scala plugin website is down?
Re: Unable to install scala in eclipse oxygen version [message #1828617 is a reply to message #1828616] Mon, 15 June 2020 05:43 Go to previous message
Scala IDE is not part of Eclipse Platform, nor is it a project under the umbrella of the Eclipse Foundation.
Please contact the Scala IDE team for any issues: http://scala-ide.org/
Previous Topic:java.lang.IllegalStateException: Workbench has not been created yet.
Next Topic:Is TLS certificate on marketplace site used by 2020-06 self-signed?
Current Time: Sat Nov 08 13:47:28 EST 2025
Powered by FUDForum. Page generated in 0.02488 seconds
