Adding item to a filtered List [message #1828496] |
Wed, 10 June 2020 15:09  |
Hi all,
I've using GlazedList with NatTable. If I filter the list, it is reduced to the items matching the filter. Now, if I change that element I get an exception while refreshing the list:
21:05:40.161 [Equinox Log Thread - Equinox Container: 9adc8e4d-3c44-497f-ad11-6d744d75bec9] ERROR org.eclipse.e4.ui.workbench - Internal Error
java.lang.IndexOutOfBoundsException: Cannot add at 2 on list of size 1
at ca.odell.glazedlists.TransformedList.add(TransformedList.java:73) ~[na:na]
at ca.odell.glazedlists.impl.Diff.replaceAll(Diff.java:84) ~[na:na]
at ca.odell.glazedlists.impl.Diff.replaceAll(Diff.java:29) ~[na:na]
at ca.odell.glazedlists.GlazedLists.replaceAll(GlazedLists.java:69) ~[na:na]
at de.mypackage.MyListTable.lambda$1(MyListTable.java:373) ~[na:na]
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40) ~[na:na]
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185) ~[na:na]
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3963) ~[na:na]
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3590) ~[na:na]
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1160) ~[na:na]
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338) ~[na:na]
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1049) ~[na:na]
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155) ~[na:na]
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:166) ~[na:na]
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) ~[na:na]
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) ~[na:na]
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) ~[na:na]
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401) ~[na:na]
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) ~[na:na]
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:na]
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:na]
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:na]
at java.base/java.lang.reflect.Method.invoke(Method.java:564) ~[na:na]
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657) ~[org.eclipse.equinox.launcher_1.5.600.v20191014-2022.jar:na]
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594) ~[org.eclipse.equinox.launcher_1.5.600.v20191014-2022.jar:na]
at org.eclipse.equinox.launcher.Main.run(Main.java:1465) ~[org.eclipse.equinox.launcher_1.5.600.v20191014-2022.jar:na]
at org.eclipse.equinox.launcher.Main.main(Main.java:1438) ~[org.eclipse.equinox.launcher_1.5.600.v20191014-2022.jar:na]
I've called
GlazedLists.replaceAll(treeFilteredIssues, listFromDatabase, false);
How can I fix this? Thanks in advance,
Ralf
[Updated on: Wed, 10 June 2020 15:15] by Moderator
FUDForum. Page generated in 0.05777 seconds
