Home » Modeling » Papyrus » tycho-surefire-plugin failed to open Papyrus diagram(CallBehaviorActionAsInteractionEditHelperAdvice doesn't exist)
tycho-surefire-plugin failed to open Papyrus diagram [message #1828463] Wed, 10 June 2020 05:17 Go to next message
There is a JUnit plug-in test that tries to open a BDD diagram and export it as image file.
If I run the test via Eclipse as "run as JUnit plug-in test" it works.
If I run the test via console using mvn install, the following errors appear:
2020-06-10 10:49:24 ERROR tools:110 - org.eclipse.papyrus.infra.tools - 0 - The class org.eclipse.papyrus.uml.diagram.interactionoverview.edit.advices.CallBehaviorActionAsInteractionEditHelperAdvice doesn't exist
java.lang.ClassNotFoundException: org.eclipse.papyrus.uml.diagram.interactionoverview.edit.advices.CallBehaviorActionAsInteractionEditHelperAdvice cannot be found by org.eclipse.papyrus.infra.tools_2.0.1.201703080851
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
        at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
        at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
        at org.eclipse.papyrus.infra.tools.util.ClassLoaderHelper.loadClass(ClassLoaderHelper.java:53)
        at org.eclipse.papyrus.infra.tools.util.ClassLoaderHelper.loadClass(ClassLoaderHelper.java:79)
        at org.eclipse.papyrus.infra.tools.util.ClassLoaderHelper.newInstance(ClassLoaderHelper.java:107)
        at org.eclipse.papyrus.infra.types.core.factories.impl.DefaultEditHelperAdviceFactory.getEditHelperAdvice(DefaultEditHelperAdviceFactory.java:30)
        at org.eclipse.papyrus.infra.types.core.factories.impl.DefaultEditHelperAdviceFactory.getEditHelperAdvice(DefaultEditHelperAdviceFactory.java:1)
        at org.eclipse.papyrus.infra.types.core.factories.impl.AbstractAdviceFactory.createEditHelperAdviceDescriptor(AbstractAdviceFactory.java:29)
        at org.eclipse.papyrus.infra.types.core.registries.AdviceConfigurationTypeRegistry.getEditHelperAdviceDecriptor(AdviceConfigurationTypeRegistry.java:93)
        at org.eclipse.papyrus.infra.types.core.utils.TypesConfigurationsCycleUtil.getDependenciesAmongAdvices(TypesConfigurationsCycleUtil.java:71)
        at org.eclipse.papyrus.infra.types.core.registries.ElementTypeSetConfigurationRegistry.loadElementTypeSetConfigurations(ElementTypeSetConfigurationRegistry.java:330)
        at org.eclipse.papyrus.infra.types.core.registries.ElementTypeSetConfigurationRegistry.init(ElementTypeSetConfigurationRegistry.java:103)
        at org.eclipse.papyrus.infra.types.core.registries.ElementTypeSetConfigurationRegistry.getInstance(ElementTypeSetConfigurationRegistry.java:84)
        at org.eclipse.papyrus.infra.types.core.TypesConfigurationsRegistryService.startService(TypesConfigurationsRegistryService.java:36)
        at org.eclipse.papyrus.infra.core.services.internal.ServiceEntry.startService(ServiceEntry.java:152)
        at org.eclipse.papyrus.infra.core.services.internal.StartStartupEntry.startService(StartStartupEntry.java:81)
        at org.eclipse.papyrus.infra.core.services.ServicesRegistry.startServices(ServicesRegistry.java:1020)
        at org.eclipse.papyrus.infra.core.services.ServicesRegistry.startRegistry(ServicesRegistry.java:488)
        at org.eclipse.papyrus.infra.ui.editor.CoreMultiDiagramEditor.loadModelAndServices(CoreMultiDiagramEditor.java:613)
        at org.eclipse.papyrus.infra.ui.editor.CoreMultiDiagramEditor.initContents(CoreMultiDiagramEditor.java:932)
        at org.eclipse.papyrus.infra.ui.editor.CoreMultiDiagramEditor.init(CoreMultiDiagramEditor.java:481)
        at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:362)
        at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:318)
        at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
        at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
        at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
        at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
        at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
        at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
        at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
        at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
        at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
        at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
        at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
        at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
        at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
        at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
        at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
        at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
        at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
        at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1324)
        at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
        at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
        at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
        at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
        at org.eclipse.swt.widgets.Display.syncExec(Display.java:4821)
        at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
        at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
        at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
        at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
        at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
        at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
        at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
        at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
        at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
        at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
        at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
        at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
        at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
        at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:617)
        at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:581)
        at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:770)
        at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
        at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1214)
        at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
        at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
        at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
        at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
        at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
        at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3107)
        at org.eclipse.ui.ide.IDE.openEditor(IDE.java:563)
        at org.eclipse.ui.ide.IDE.openEditor(IDE.java:518)
        at org.polarsys.chess.contracts.profile.chesscontract.util.EntityUtil.openCurrentModelIntoEditor(EntityUtil.java:249)
        at org.polarsys.chess.contracts.verificationService.test.runtime.tests.TestBasicOperations.openEditor(TestBasicOperations.java:269)
        at org.polarsys.chess.contracts.verificationService.test.runtime.tests.TestBasicOperations.testGenerationDocumentation(TestBasicOperations.java:208)
        at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
        at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
        at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
        at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
        at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:26)
        at org.junit.rules.Verifier$1.evaluate(Verifier.java:35)
        at org.junit.rules.TestWatcher$1.evaluate(TestWatcher.java:55)
        at org.eclipse.papyrus.junit.utils.rules.ProjectFixture$1.evaluate(ProjectFixture.java:162)
        at org.junit.rules.RunRules.evaluate(RunRules.java:20)
        at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
        at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
        at org.eclipse.papyrus.junit.framework.classification.ClassificationRunner.access$0(ClassificationRunner.java:1)
        at org.eclipse.papyrus.junit.framework.classification.ClassificationRunner$1.runChild(ClassificationRunner.java:56)
        at org.eclipse.papyrus.junit.framework.classification.ClassificationRunnerImpl.runChild(ClassificationRunnerImpl.java:85)
        at org.eclipse.papyrus.junit.framework.classification.ClassificationRunner.runChild(ClassificationRunner.java:84)
        at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
        at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
        at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
        at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
        at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
        at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
        at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
        at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:264)
        at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:153)
        at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:124)
        at org.apache.maven.surefire.util.ReflectionUtils.invokeMethodWithArray2(ReflectionUtils.java:208)
        at org.apache.maven.surefire.booter.ProviderFactory$ProviderProxy.invoke(ProviderFactory.java:156)
        at org.apache.maven.surefire.booter.ProviderFactory.invokeProvider(ProviderFactory.java:82)
        at org.eclipse.tycho.surefire.osgibooter.OsgiSurefireBooter.run(OsgiSurefireBooter.java:95)
        at org.eclipse.tycho.surefire.osgibooter.AbstractUITestApplication$1.run(AbstractUITestApplication.java:35)
        at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
        at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
        at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4211)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3827)
        at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
        at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
        at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
        at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
        at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
        at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
        at org.eclipse.tycho.surefire.osgibooter.UITestApplication.runApplication(UITestApplication.java:31)
        at org.eclipse.tycho.surefire.osgibooter.AbstractUITestApplication.run(AbstractUITestApplication.java:120)
        at org.eclipse.tycho.surefire.osgibooter.UITestApplication.start(UITestApplication.java:37)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
        at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
2020-06-10 10:49:24 ERROR core:110 - org.eclipse.papyrus.infra.core - 0 - Unexpected Error
org.eclipse.papyrus.infra.core.services.ServiceMultiException: Multiple exceptions
----- exceptions : ----------
ElementTypesConfigurationsRegistryService : java.lang.NullPointerException
        at org.eclipse.papyrus.infra.core.services.ServicesRegistry.startRegistry(ServicesRegistry.java:456)
The build part of the pom.xml is the following:
<build>
		<plugins>
			<plugin>
				<groupId>org.eclipse.tycho</groupId>
				<artifactId>tycho-surefire-plugin</artifactId>
				<configuration>
					<failIfNoTests>false</failIfNoTests>
					<product>org.eclipse.platform.ide</product>
					<useUIHarness>true</useUIHarness>
					<useUIThread>true</useUIThread>
				</configuration>
			</plugin>
		</plugins>
	</build>
Do you have any idea related to this problem?
Thanks in advice,
Alberto
[Updated on: Wed, 10 June 2020 05:17] by Moderator
Re: tycho-surefire-plugin failed to open Papyrus diagram [message #1828471 is a reply to message #1828463] Wed, 10 June 2020 07:16 Go to previous messageGo to next message
This is a side-effect of this bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=543726
When running the tests from Eclipse/PDE, all plug-ins from the workspace/target platform are included, so the tests can find this class, even with the incorrect dependency specified. However, Maven/Tycho runs with a much smaller target platform, where the plug-in will not be included unless there is an explicit (direct or indirect) dependency from the test plug-in to the required bundle.
Camille
Re: tycho-surefire-plugin failed to open Papyrus diagram [message #1828474 is a reply to message #1828471] Wed, 10 June 2020 08:11 Go to previous messageGo to next message
Where should I include the missing dependencies?
Re: tycho-surefire-plugin failed to open Papyrus diagram [message #1828479 is a reply to message #1828474] Wed, 10 June 2020 08:49 Go to previous messageGo to next message
It's not exactly a "missing" dependency; it's more like an invalid, implicit dependency that shouldn't exist at all.
But as a workaround, you can add a dependency from the plug-in that contains the failing test to the Interaction Overview diagram plug-in (Or somehow make sure that the Interaction Overview Diagram is present in the test runtime)
HTH,
Camille
Re: tycho-surefire-plugin failed to open Papyrus diagram [message #1828481 is a reply to message #1828479] Wed, 10 June 2020 09:20 Go to previous messageGo to next message
I added some dependencies listed in the console (such as org.eclipse.papyrus.uml.diagram.interactionoverview) in the manifest of the test plugin, and now the diagrams are exported as images.
The problem now is that the images have missing or bad graphical components.
In attached the 2 generated images and related desired images.
Re: tycho-surefire-plugin failed to open Papyrus diagram [message #1828483 is a reply to message #1828481] Wed, 10 June 2020 09:56 Go to previous messageGo to next message
It looks like some CSS files are missing. Maybe you need another dependency, to the plug-in that contributes the SysML CSS Files? (Or maybe directly to the SysML Architecture definition, that should reference everything that is related to both SysML Diagram definitions & semantics)
HTH,
Camille
Re: tycho-surefire-plugin failed to open Papyrus diagram [message #1828561 is a reply to message #1828483] Fri, 12 June 2020 03:33 Go to previous message
I added some org.eclipse.gmf.runtime.diagram.* and org.eclipse.papyrus.sysml.* plugins and it works!
Previous Topic:Restore a project
Next Topic:Class diagram and key word throws
Current Time: Mon Jul 28 09:37:10 EDT 2025
Powered by FUDForum. Page generated in 0.03985 seconds
