Home » Eclipse Projects » Eclipse Platform » java.lang.IllegalStateException: Workbench has not been created yet.(errors with JUnit plug-in tests via console )
java.lang.IllegalStateException: Workbench has not been created yet. [message #1828434] Tue, 09 June 2020 10:56 Go to next message
I have a suite of tests that run with no errors if it is executed inside the Eclipse environment (run as JUnit plug-in tests). The product chosen is "org.eclipse.platform.ide".
But, if the suite of tests is executed via console using Maven (mvn install) it appers the following error:
In this case I haven't set the "org.eclipse.platform.ide" product.
Do you have any idea to solve this issue?
Thanks in advice,
Alberto
Re: java.lang.IllegalStateException: Workbench has not been created yet. [message #1828456 is a reply to message #1828434] Wed, 10 June 2020 03:24 Go to previous messageGo to next message
Mostly people building Eclipse software use Maven with Tycho and use tycho-surefire-plugin to launch plugin tests.
Re: java.lang.IllegalStateException: Workbench has not been created yet. [message #1828459 is a reply to message #1828456] Wed, 10 June 2020 04:18 Go to previous messageGo to next message
I'm using "tycho-surefire-plugin". This is the build part of the pom.xml:
<build>
<plugins>
<plugin>
<groupId>org.eclipse.tycho</groupId>
<artifactId>tycho-surefire-plugin</artifactId>
<configuration>
<failIfNoTests>false</failIfNoTests>
<product>org.eclipse.platform.ide</product>
</configuration>
</plugin>
</plugins>
</build>
Re: java.lang.IllegalStateException: Workbench has not been created yet. [message #1828478 is a reply to message #1828459] Wed, 10 June 2020 08:44 Go to previous messageGo to next message
Does the test really launch an IDE with a workspace? Where you're running it, is able to create a display? If you can look at the workspace, you can probably find more details in the log.
Re: java.lang.IllegalStateException: Workbench has not been created yet. [message #1828482 is a reply to message #1828478] Wed, 10 June 2020 09:26 Go to previous message
Now it works.
I modified the pom.xml as follow:
<build>
<plugins>
<plugin>
<configuration>
<useUIHarness>true</useUIHarness>
<useUIThread>true</useUIThread>
</configuration>
</plugin>
</plugins>
</build>
Previous Topic:Edit environment variables and start project build automatically with Python
Next Topic:Unable to install scala in eclipse oxygen version
Current Time: Mon Jul 21 07:03:57 EDT 2025
Powered by FUDForum. Page generated in 0.05837 seconds
