| WireAsset does not start reading [message #1828350] |
Mon, 08 June 2020 05:26  |
Hi all,
I've a problem in reading of the WireAsset. After a long time with connection problems, Kura seems to stop tryng the reading of all the assets; reading threads do not even starts. For example, the OPC UA driver does not even write in the log file "Connecting to OPC-UA...".
This happens for all the different drivers simultaneously (OPCUA, Modbus and a self-made driver). It seems that the timer components linked to assets stops working; other components (not WireAsset) work good.
If I call a read API with Postman for the blocked assets, it works fine.
Is it a known problem? There are some known reasons why this can happen?
Regards.
FUDForum. Page generated in 0.05851 seconds
