Scout Create Wizard not working properly [message #1828244] |
Thu, 04 June 2020 12:17  |
I´ve got a very weird problem. When I try to create a new Form through the scout wizard, it will be created but the code wont be coloured in a normal way. And the autocomplete feature wont work as well, it will give me results to autocomplete from but when I press enter nothing happens. In other forms/classes this still works. Also the services that are created with the form, are faulty as well. I´ll provide Screenshots of it. Does anyone know how to resolve this?
I also tried importing the project from SVN into a new Workspace. There I also have the same problem.
What i did:
Right click on a Maven Package -> New -> Other -> Scout -> Form -> Next -> Enter Name -> Finish
I still have Scout v9. Its weird because before I could create forms and stuff through the wizard.
Thank you all for your answers and help.
Re: Scout Create Wizard not working properly [message #1828260 is a reply to message #1828245] |
Fri, 05 June 2020 03:24  |
Hi Luis
I don't know what the problem was in your case, but here are some general tips:
- Make sure that Project > Build automatically is checked.
- Sometimes, running "Maven > Update project" on all projects can help (Alt-F5).
- If it was caused by an error in a plugin, you might find some clues to the cause in the Eclipse error log (Window > Show view > Other... > Error Log).
Beat
FUDForum. Page generated in 0.04491 seconds
