Home » Modeling » Papyrus » MacOS, UseCase, Actors not stick characters(Version: 2020-06 (4.16.0))
MacOS, UseCase, Actors not stick characters [message #1828158] |
Tue, 02 June 2020 22:55  |
I am not sure why, but the actors aren't showing as a stick character. I noticed that in 2017 folks mentioned there's a patch to fix this issue, so I would have imagined this would be in place 2020-06. Am I missing something?
Re: MacOS, UseCase, Actors not stick characters [message #1829957 is a reply to message #1828165] |
Tue, 14 July 2020 14:58   |
HI Carsten,
Finally what I did to debug - essentially eliminated the problem. Albeit left it lingering for the next individual. I'll go back and recreate the steps that led to the problem to aid further in diagnosing/resolving.
Originally I had CDT C/C++, Papyrus, BPMN2, all installed in one Eclipse IDE on my MacOS. After trying for hours to create the 'Stickman', I gave up and went to do some work in BPMN only to obtain error messages there. Fortunately the C/C++ stuff worked (though connecting GDB has some reliability issues that I work around. Anyhoo.... without digressing too far. What I observed is the error messages within the BPMN plug-ins implied that there was an inter-op issue with other plug-ins. Then I began to look at the array of shared components between Papyrus and BPMN and realized I had a nightmare if I was going to try and debug. Instead.... as I had a license to Parallels, I chose to create n-installs of MacOS using Parallels, and the install a unique Eclipse IDE for each C/C++, BPMN, UML and SysML effort. These virtualized installs - eliminated the inter-op error messages for BPMN, with the added benefit that the elusive 'stickman' appeared for the UseCase diagrams in the UML/Eclipse install. My suggestion, is that others who have large sets of tools/projects installed into Eclipse, where they are running into mysterious bugs may want to opt to use the same technique.
Before switching the the virtualized OS solution, I tried multiple workspaces for Eclipse with unique installs for each Eclipse project. That didn't work, and I don't know why. I chose the virtualized OS solution as it seemed like at least I could get productive :), albeit I did leave a lingering issue. I'll put it on my todo list to further diagnose the difference between the Eclipse/UML install that had the other projects installed too, and the pristine Eclipse/UML install that works.
Re: MacOS, UseCase, Actors not stick characters [message #1843083 is a reply to message #1829957] |
Wed, 14 July 2021 11:51  |
Sam Warner wrote on Tue, 14 July 2020 18:58HI Carsten,
This is a great solution, except I have no idea what any of it means. I installed Papyrus 4.8 and SysML 1.4 and have the same issue. Not using C++ or anything else that I know of.
Current Time: Mon Jul 28 06:21:09 EDT 2025
Powered by FUDForum. Page generated in 0.05052 seconds
