Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Compiling forte with xilinx toolchain failed
Compiling forte with xilinx toolchain failed [message #1828095] Mon, 01 June 2020 09:11 Go to next message
when i choose the arm-xilinx-linux-gnueabi-gcc,arm-xilinx-linux-gnueabi-g++
under toolchain in cmake, the errors occur
The C compiler identification is unknown
The CXX compiler identification is unknown
So can't we use the xlinx toolchain?
Re: Compiling forte with xilinx toolchain failed [message #1828118 is a reply to message #1828095] Tue, 02 June 2020 03:02 Go to previous messageGo to next message
With that information I must admit I can not say it. But i would guess it is a setting issue because sofar we could get every toolchain working.
Re: Compiling forte with xilinx toolchain failed [message #1828120 is a reply to message #1828118] Tue, 02 June 2020 03:15 Go to previous messageGo to next message
I installed vivado 2019.2 then i use the gnu under E:\Xilinx\Vitis\2019.2\gnu\aarch32\nt\gcc-arm-linux-gnueabi\bin
the the cmake-gui can configure it, but i don't know how to link a library(.a) with forte, in cmake-gui or develepment tool
Re: Compiling forte with xilinx toolchain failed [message #1828123 is a reply to message #1828120] Tue, 02 June 2020 03:23 Go to previous messageGo to next message
never used that thing. any log messages that could help? more detailed error messages
Re: Compiling forte with xilinx toolchain failed [message #1828124 is a reply to message #1828123] Tue, 02 June 2020 03:36 Go to previous messageGo to next message
Check for working C compiler: E:/M1600/Codesourcery/bin/arm-xilinx-linux-gnueabi-gcc
Check for working C compiler: E:/M1600/Codesourcery/bin/arm-xilinx-linux-gnueabi-gcc - broken
CMake Error at D:/1600/cmake-3.17.0-rc3-win64-x64/share/cmake-3.17/Modules/CMakeTestCCompiler.cmake:60 (message):
The C compiler
"E:/M1600/Codesourcery/bin/arm-xilinx-linux-gnueabi-gcc"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: D:/1600/forte-incubation_1.12.0/bin12/CMakeFiles/CMakeTmp
Run Build Command(s):D:/PROGRA~1/mingw64/bin/mingw32-make.exe cmTC_d7343/fast && D:/PROGRA~1/mingw64/bin/mingw32-make.exe -f CMakeFiles\cmTC_d7343.dir\build.make CMakeFiles/cmTC_d7343.dir/build
mingw32-make.exe[1]: Entering directory 'D:/1600/forte-incubation_1.12.0/bin12/CMakeFiles/CMakeTmp'
Building C object CMakeFiles/cmTC_d7343.dir/testCCompiler.c.o
E:\M1600\Codesourcery\bin\arm-xilinx-linux-gnueabi-gcc -o CMakeFiles\cmTC_d7343.dir\testCCompiler.c.o -c D:\1600\forte-incubation_1.12.0\bin12\CMakeFiles\CMakeTmp\testCCompiler.c
process_begin: CreateProcess(E:\M1600\Codesourcery\bin\arm-xilinx-linux-gnueabi-gcc, E:\M1600\Codesourcery\bin\arm-xilinx-linux-gnueabi-gcc -o CMakeFiles\cmTC_d7343.dir\testCCompiler.c.o -c D:\1600\forte-incubation_1.12.0\bin12\CMakeFiles\CMakeTmp\testCCompiler.c, ...) failed.
make (e=193): Error 193
mingw32-make.exe[1]: *** [CMakeFiles\cmTC_d7343.dir\build.make:82: CMakeFiles/cmTC_d7343.dir/testCCompiler.c.o] Error 193
mingw32-make.exe[1]: Leaving directory 'D:/1600/forte-incubation_1.12.0/bin12/CMakeFiles/CMakeTmp'
mingw32-make.exe: *** [Makefile:137: cmTC_d7343/fast] Error 2
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:17 (PROJECT)
Configuring incomplete, errors occurred!
See also "D:/1600/forte-incubation_1.12.0/bin12/CMakeFiles/CMakeOutput.log".
See also "D:/1600/forte-incubation_1.12.0/bin12/CMakeFiles/CMakeError.log".
  • Attachment: snap1.png
    (Size: 9.32KB, Downloaded 98 times)
[Updated on: Tue, 02 June 2020 03:37] by Moderator
Re: Compiling forte with xilinx toolchain failed [message #1828126 is a reply to message #1828124] Tue, 02 June 2020 03:49 Go to previous messageGo to next message
the interesting information would be in:
but i also see a few things that you could consider:
1. I don't think that E:\M1600\Codesourcery\bin is the right directory as target root. In my setups the bin was never the correct one
2. if it is a very special platform you may need a target configuration cmake file with additional compiler and linker flags
3. since quite some time we recommend that the build directory should not be within the forte code that you downloaded. This makes it easier for you to seperate your developments from the offical forte code.
Re: Compiling forte with xilinx toolchain failed [message #1828129 is a reply to message #1828126] Tue, 02 June 2020 04:18 Go to previous messageGo to next message
both
E:\M1600\Codesourcery\bin and E:/M1600/Codesourcery/arm-xilinx-linux-gnueabi/bin
didn't work, they had the same error in CMakeError.log
Compiler: E:/M1600/Codesourcery/arm-xilinx-linux-gnueabi/bin/gcc
Build flags:
Id flags:
The output was:
%1 is not a valid Win32 application
i downloaded two different versions of xilinx toolchian, but none of them worked.
Re: Compiling forte with xilinx toolchain failed [message #1828130 is a reply to message #1828126] Tue, 02 June 2020 04:20 Go to previous messageGo to next message
No Message Body
Re: Compiling forte with xilinx toolchain failed [message #1828135 is a reply to message #1828129] Tue, 02 June 2020 05:15 Go to previous messageGo to next message
joy woo wrote on Tue, 02 June 2020 08:18
both
for me it is never a bin directory. for any linaro toolchain always the toolchain root file seems to work best.
Build flags:
Id flags:
The output was:
I think there are some cross compilation settings missing. Cmake is trying to check if the application generated works for your host OS. There are some options that can tweak that. Please search for cross compilation and CMake to check for them.
Re: Compiling forte with xilinx toolchain failed [message #1828141 is a reply to message #1828135] Tue, 02 June 2020 10:16 Go to previous messageGo to next message
how to add libary .a into forte in cmake-gui ?
Re: Compiling forte with xilinx toolchain failed [message #1828142 is a reply to message #1828141] Tue, 02 June 2020 10:20 Go to previous messageGo to next message
linker options?
Re: Compiling forte with xilinx toolchain failed [message #1828143 is a reply to message #1828142] Tue, 02 June 2020 10:23 Go to previous messageGo to next message
I didn't find it
  • Attachment: s2.png
    (Size: 46.00KB, Downloaded 96 times)
Re: Compiling forte with xilinx toolchain failed [message #1828416 is a reply to message #1828143] Tue, 09 June 2020 08:42 Go to previous message
in CMakeList.txt under forte/src
if(FORTE_BUILD_EXECUTABLE)
ADD_EXECUTABLE (forte $<TARGET_OBJECTS:FORTE_LITE> ${SOURCE_EXECUTABLE_CPP} ${FORTE_EXECUTABLE_H})
set_target_properties(forte PROPERTIES LINK_FLAGS "${link_flags}")
TARGET_LINK_LIBRARIES (forte ${LINK_LIBRARY})
TARGET_LINK_LIBRARIES (forte ${ADT_LIBRARIES})
ADD_DEPENDENCIES (forte FORTE_LITE)
install(TARGETS forte RUNTIME DESTINATION bin)
message("Building executable")
endif(FORTE_BUILD_EXECUTABLE)
in another file CmakeList.txt
i add :
forte_add_include_directories(${CMAKE_CURRENT_SOURCE_DIR})
forte_add_sourcefile_h (ADT_Motion_Pulse.h ADT_Motion_Unit.h)
then i can compile static library into forte
Previous Topic:Type Export in 4diac 1.12.2
Next Topic:forte+freertos+lwip on stm32 flash problem
Current Time: Sat Jul 26 22:30:21 EDT 2025
Powered by FUDForum. Page generated in 0.05947 seconds
