ElementCollection List<String> Exception during deployment [message #1828023] |
Fri, 29 May 2020 05:42  |
Hi all,
I hope somebody can help me out with this issue, for which I could not find an answer to.
I am using ElementCollections for a List of Strings in which I store some configuration items.
@Entity
@Table(name = "T_TABLE")
public class MyEntity implements Serializable {
private static final long serialVersionUID = 1L;
@Id
@GeneratedValue(strategy = GenerationType.SEQUENCE, generator = "REPORT_SEQ")
@SequenceGenerator(name = "REPORT_SEQ", sequenceName = "REPORT_SEQ", allocationSize = 1, initialValue = 100)
private long id;
@ElementCollection(targetClass = java.lang.String.class, fetch = FetchType.EAGER)
private List<String> users = new ArrayList<>();
... getter and setters...
When I deploy my code on a Payara 5.193 and 5.194 full I get the following exception, but the application runs totally fine.
I also get the same error when testing locally with H2DB.
java.lang.ClassNotFoundException: java.util.Listjava.lang.String
at java.net.URLClassLoader.findClass(URLClassLoader.java:382)
at java.lang.ClassLoader.loadClass(ClassLoader.java:419)
at java.lang.ClassLoader.loadClass(ClassLoader.java:352)
at org.apache.felix.framework.BundleWiringImpl.findClassOrResourceByDelegation(BundleWiringImpl.java:1475)
at org.apache.felix.framework.BundleWiringImpl.access$300(BundleWiringImpl.java:79)
at org.apache.felix.framework.BundleWiringImpl$BundleClassLoader.loadClass(BundleWiringImpl.java:1982)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAsmFactory.getVirtualMetadataClass(MetadataAsmFactory.java:542)
at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAsmFactory.buildClassMetadata(MetadataAsmFactory.java:143)
at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAsmFactory.getMetadataClass(MetadataAsmFactory.java:177)
at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAccessibleObject.getMetadataClass(MetadataAccessibleObject.java:73)
at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAnnotatedElement.getRawClassWithGenerics(MetadataAnnotatedElement.java:395)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.getRawClassWithGenerics(MappingAccessor.java:965)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.getReferenceClassWithGenerics(MappingAccessor.java:996)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.DirectCollectionAccessor.processDirectCollectionMapping(DirectCollectionAccessor.java:463)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.ElementCollectionAccessor.process(ElementCollectionAccessor.java:875)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processDirectCollectionAccessors(MetadataProject.java:1622)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processStage3(MetadataProject.java:1911)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processORMMetadata(MetadataProcessor.java:584)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:629)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:2003)
at org.eclipse.persistence.jpa.PersistenceProvider.createContainerEntityManagerFactoryImpl(PersistenceProvider.java:350)
at org.eclipse.persistence.jpa.PersistenceProvider.createContainerEntityManagerFactory(PersistenceProvider.java:316)
at org.glassfish.persistence.jpa.PersistenceUnitLoader.loadPU(PersistenceUnitLoader.java:207)
at org.glassfish.persistence.jpa.PersistenceUnitLoader.<init>(PersistenceUnitLoader.java:114)
at org.glassfish.persistence.jpa.JPADeployer$1.visitPUD(JPADeployer.java:225)
at org.glassfish.persistence.jpa.JPADeployer$PersistenceUnitDescriptorIterator.iteratePUDs(JPADeployer.java:525)
at org.glassfish.persistence.jpa.JPADeployer.createEMFs(JPADeployer.java:240)
at org.glassfish.persistence.jpa.JPADeployer.prepare(JPADeployer.java:170)
at com.sun.enterprise.v3.server.ApplicationLifecycle.prepareModule(ApplicationLifecycle.java:1045)
at com.sun.enterprise.v3.server.ApplicationLifecycle.prepare(ApplicationLifecycle.java:475)
at org.glassfish.deployment.admin.DeployCommand.execute(DeployCommand.java:538)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:558)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:554)
at javax.security.auth.Subject.doAs(Subject.java:360)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$2.execute(CommandRunnerImpl.java:553)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$3.run(CommandRunnerImpl.java:584)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$3.run(CommandRunnerImpl.java:576)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:575)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:1496)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.access$1300(CommandRunnerImpl.java:120)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1878)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1754)
at org.glassfish.admin.rest.resources.admin.CommandResource.executeCommand(CommandResource.java:409)
at org.glassfish.admin.rest.resources.admin.CommandResource.execCommandSimpInMultOut(CommandResource.java:236)
at sun.reflect.GeneratedMethodAccessor411.invoke(Unknown Source)
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52)
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:124)
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:167)
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:176)
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:79)
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:469)
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:391)
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:80)
at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:253)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244)
at org.glassfish.jersey.internal.Errors.process(Errors.java:292)
at org.glassfish.jersey.internal.Errors.process(Errors.java:274)
at org.glassfish.jersey.internal.Errors.process(Errors.java:244)
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265)
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:232)
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:680)
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:353)
at org.glassfish.admin.rest.adapter.JerseyContainerCommandService$3.service(JerseyContainerCommandService.java:179)
at org.glassfish.admin.rest.adapter.RestAdapter.service(RestAdapter.java:189)
at com.sun.enterprise.v3.services.impl.ContainerMapper$HttpHandlerCallable.call(ContainerMapper.java:520)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:217)
at org.glassfish.grizzly.http.server.HttpHandler.runService(HttpHandler.java:182)
at org.glassfish.grizzly.http.server.HttpHandler.doHandle(HttpHandler.java:156)
at org.glassfish.grizzly.http.server.HttpServerFilter.handleRead(HttpServerFilter.java:218)
at org.glassfish.grizzly.filterchain.ExecutorResolver$9.execute(ExecutorResolver.java:95)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:260)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:177)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:109)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:88)
at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:53)
at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:524)
at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:89)
at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.run0(WorkerThreadIOStrategy.java:94)
at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.access$100(WorkerThreadIOStrategy.java:33)
at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy$WorkerThreadRunnable.run(WorkerThreadIOStrategy.java:114)
at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:569)
at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:549)
at java.lang.Thread.run(Thread.java:748)
<persistence xmlns="...xmlns.jcp.org/xml/ns/persistence"
xmlns:xsi="...www.w3.org/2001/XMLSchema-instance" version="2.2"
xsi:schemaLocation=".../xmlns.jcp.org/xml/ns/persistence ...xmlns.jcp.org/xml/ns/persistence/persistence_2_2.xsd">
<persistence-unit name="punit" transaction-type="JTA">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<jta-data-source>java:global/app/AppDS</jta-data-source>
<class>FullyQualifiedNameToEntity</class>
<properties>
<property name="eclipselink.target-database"
value="org.eclipse.persistence.platform.database.PostgreSQLPlatform" />
<property name="eclipselink.jdbc.batch-writing" value="JDBC" />
<property name="eclipselink.jdbc.batch-writing.size"
value="1000" />
<property name="eclipselink.logging.level" value="FINE" />
<property name="eclipselink.logging.level.sql" value="FINE" />
<property name="eclipselink.logging.parameters" value="true" />
</properties>
</persistence-unit>
</persistence>
I use this type of ElementCollection multiple times, but I only get one exception thrown during deployment.
Does anybody have an idea what I am doing wrong?
Re: ElementCollection List<String> Exception during deployment [message #1828440 is a reply to message #1828431] |
Tue, 09 June 2020 11:49  |
I'm going to try to saying nothing as I made the initial assumption your stack was an exception preventing your application from running. But if you don't have an issue, there isn't one I can see.
Feel free to log a bug about the FINE message it is logging; I don't know how urgent it is or if anyone will ever get to it, but might help as another searchable reference should someone else see the same message and wonder about it.
[Updated on: Tue, 09 June 2020 11:50] by Moderator
FUDForum. Page generated in 0.26268 seconds
