Home » Eclipse Projects » EGit / JGit » EGit not recognising git repositories downloaded using repo tool
EGit not recognising git repositories downloaded using repo tool [message #1828070] Sun, 31 May 2020 12:24 Go to next message
Hi Team,
I am trying to add existing git repositories present in my local machine to Eclipse.
Please note that the local repositories are cloned using "repo tool" and not using "git clone".
But these repositories are not getting listed when I search for the available local git repositories.
However the same repositories are available when we clone them locally, using "git clone".
Steps I followed:
1. Add an existing local repository
index.php/fa/38219/0/
2. Go to the local path where the repository is available
index.php/fa/38220/0/
As we can see the projects are not getting listed in the search dialog box.
Kindly let me know whether the eclipse EGit supports repositories cloned using repo tool.
Kindly help me in resolving this issue.
Thank you
Re: EGit not recognising git repositories downloaded using repo tool [message #1828074 is a reply to message #1828070] Sun, 31 May 2020 17:50 Go to previous messageGo to next message
Does git from the command line recognize them as repositories?
Re: EGit not recognising git repositories downloaded using repo tool [message #1828083 is a reply to message #1828074] Mon, 01 June 2020 01:40 Go to previous messageGo to next message
What is "repo tool"?
Re: EGit not recognising git repositories downloaded using repo tool [message #1828111 is a reply to message #1828074] Tue, 02 June 2020 01:34 Go to previous messageGo to next message
@Nitin Dahyabhai :
Yess it is getting recognised
[Updated on: Tue, 02 June 2020 01:35] by Moderator
Re: EGit not recognising git repositories downloaded using repo tool [message #1828112 is a reply to message #1828083] Tue, 02 June 2020 01:39 Go to previous messageGo to next message
@Thomas Wolf :
Repo is a tool built on top of Git. Repo helps manage many Git repositories, does the uploads to revision control systems, and automates parts of the development .
https://gerrit.googlesource.com/git-repo/
Re: EGit not recognising git repositories downloaded using repo tool [message #1828127 is a reply to message #1828112] Tue, 02 June 2020 03:50 Go to previous messageGo to next message
I don't know what that repo tool does. The EGit dialog uses JGit to figure out whether a directory contains a git repository. JGit assumes that git repositories are either directories named ".git" or having the extension ".git" (bare repos), and that these directories contain an "objects" subdirectory and a "refs" subdirectory and either a "reftable" or a valid HEAD. A valid HEAD is a file called "HEAD" containing either a 40-hex digit SHA1 or starting with "ref: refs/".
Looks like the clones created by this repo tool fail this check? Or does it put them in some other directory?
Re: EGit not recognising git repositories downloaded using repo tool [message #1828152 is a reply to message #1828127] Tue, 02 June 2020 13:10 Go to previous messageGo to next message
Also, where does this repo tool put the git clones? I see at https://source.android.com/setup/develop/repo that "repo init" at least creates some ".repo" subdirectory. Are the git clones also inside that?
Finally, what version of EGit are you using? In current EGit the "Add Git Repositories" dialog you show has an additional checkbox "Skip hidden directories". (If checked, it would skip ".repo" on Linux.)
Re: EGit not recognising git repositories downloaded using repo tool [message #1828157 is a reply to message #1828152] Tue, 02 June 2020 21:32 Go to previous messageGo to next message
index.php/fa/38233/0/Hello Thomas Wolf,
Thank you for the sharing.
I have updated the git plugin and again the same issue persists.
When getting cloned from repo init ,
".repo" subdirectory is created and the .git folders for each clone is inside that.
Hence this .repo subdirectory is getting recognised but not the working directory of the clone where source code is present.
Here are the attachments,
1) When I search the working dir, where the source code is available.
index.php/fa/38232/0/
2) When I search the .repo alone,
Here we can see the .git inside the " .repo direcotry" is getting recognized, but we need the .git inside the source code folder to be recognized.
Also I could see , the sub directories such as objects, refs, inside .git of source code folder are symlinks pointing to corresponding objects, refs of .repo
index.php/fa/38234/0/
index.php/fa/38235/0/
  • Attachment: step3.PNG
    (Size: 23.79KB, Downloaded 580 times)
  • Attachment: step4.png
    (Size: 107.38KB, Downloaded 613 times)
  • Attachment: step5.PNG
    (Size: 26.62KB, Downloaded 570 times)
[Updated on: Wed, 03 June 2020 10:37] by Moderator
Re: EGit not recognising git repositories downloaded using repo tool [message #1828195 is a reply to message #1828157] Wed, 03 June 2020 10:55 Go to previous message
Symlinks are not files. I'm not even sure JGit could work with such a fake .git directory. And JGit doesn't support git-worktree (multiple working trees per git repo) yet.
Previous Topic:Behavior of JGit regarding links?
Next Topic:Errors in Eclipse 2020-03 with latest ADT
Current Time: Thu Oct 30 20:01:41 EDT 2025
Powered by FUDForum. Page generated in 0.26242 seconds
