Home » Modeling » EMF » DataBinding Help(Need help to upgrade the current databinding code)
DataBinding Help [message #1827999] Thu, 28 May 2020 16:26 Go to next message
We have code that was created in Eclipse Galileo. I need to upgrade the Eclipse to the latest version. I run into an issue that the interface IObservableValue changed definition to IObservableValue<T>
I'm looking for new example how the EMF databinding should be defined but can't find any information
My code is simple:
    public boolean doDataBinding(EditingDomain domain, EObject input) {
        binding = new EMFDataBindingContext();
        IWidgetValueProperty<Text, String> prop = WidgetProperties.text(SWT.Modify);
        IEMFValueProperty value = EMFEditProperties.value(domain, fldFeature);
        IObservableValue<?> ob = value.observe(input);
        binding.bindValue(prop.observeDelayed(FIELD_INPUT_DELAY, txtControl), ob);
        return false;
The warning I get on the code "value.observe(input)" is:
Type safety: The method observe(Object) belongs to the raw type IValueProperty. References to generic type IValueProperty<S,T> should be parameterized
How do I do that???
Where can I find sample code that will help me do databinding for all types of widgets?
Yigal
Re: DataBinding Help [message #1828006 is a reply to message #1827999] Fri, 29 May 2020 00:20 Go to previous messageGo to next message
The EMF APIs have not been modified to introduce generics so there's no way to avoid this problem. Others have added their own "helper" static method to centralize the annotations to suppress the warnings.
Re: DataBinding Help [message #1828009 is a reply to message #1828006] Fri, 29 May 2020 02:45 Go to previous message
Presumably your code works, so Java is 'happy' with the partial type information. The easiest approach is to add e.g. @SuppressWarnings("rawtypes") perhaps to individual declarations, perhaps to methods / classes / projects.
If some parameters are already defined then you need to go along with them, otherwise <?> or <Object> will probably do.
Ultimately genetics enable you to write safer code so its best to use them rather than fight them. As Ed Merks writes, helper methods can help.I have a variety of XXXUtil classes for such purposes.
Ed Willink
Previous Topic:Manage Tool Documentation
Next Topic:[CDO] Offline Clone keeps connecting and disconnecting to master
Current Time: Mon Jul 21 03:58:51 EDT 2025
Powered by FUDForum. Page generated in 0.08837 seconds
