Home » Modeling » Graphiti » Problem with graphiti 0.11.4 dependency
Problem with graphiti 0.11.4 dependency [message #1827839] Mon, 25 May 2020 06:19 Go to next message
Greetings graphiti community,
I take part in the development of a project which requires graphiti 0.11.4. Until recently I grabbed graphiti from the software site at the graphiti archive, but now I am getting an error message at the target definition telling that the artifacts cannot be found.
I tried with the zip file listed next to the software site URL at the graphiti download page, but I get the same result.
Looking to the zip contents and comparing to more recent versions (from version 0.14.0), I observed that version 0.11.4 misses a .jar file for every artifact. ¿Maybe the upload site is broken?
I have attached some captures of what I have described to this post.
Sorry if this is not the appropriate place to discuss this issue, but I hope you can help me to solve it.
Thank you in advance.
Re: Problem with graphiti 0.11.4 dependency [message #1827904 is a reply to message #1827839] Tue, 26 May 2020 11:46 Go to previous messageGo to next message
Hi Jose,
I just tried to install 0.11.4 into a fresh Eclipse on my laptop and used the update site https://archive.eclipse.org/graphiti/updates/0.11.4/ for that. I worked for me without errors, there are no missing JARs. Maybe that was a temporary issue, so could you just retry?
Also I'm not aware of any recent changes to that repository. Just as a side note, that Graphiti version is now almost 6 Years old. Have you thought about upgrading the a newer version?
Michael
Re: Problem with graphiti 0.11.4 dependency [message #1828241 is a reply to message #1827904] Thu, 04 June 2020 12:07 Go to previous messageGo to next message
Hi Michael,
Thank you for your fast response and sorry for the delay. I have tried again a minute ago. This is what I have done:
1. download a fresh copy of Eclipse for Eclipse commiters
2. start Eclipse, pick a non existing directory as workspace
3. add a new Target Platform with nothing
4. add Luna software site (http://download.eclipse.org/releases/luna/) and Eclipse Scout and GEF SDK
5. add Graphiti 0.11.4 update site (http://archive.eclipse.org/graphiti/updates/0.11.4) and Graphiti
I get the same "Artifact not found" error message. If I replace Graphiti update site with the downloadable zip, the results are the same.
That version of Graphiti is a dependency for a third party plug-in that we use at our project and that is not longer actively mantained. We prefer not to modify the third party plug-in, though. So, that's the reason why we need Graphiti 0.11.4.
I realised that I cannot get Graphiti artifacts from the archive update site because I lost my workspace not long ago and I had to configure the project development environment again.
Thank you once more.
Jose
Re: Problem with graphiti 0.11.4 dependency [message #1828242 is a reply to message #1828241] Thu, 04 June 2020 12:13 Go to previous message
Hi again Michael,
I tried with version 0.11.2 from Luna software site and it is working. Graphiti 0.11.4 from Graphiti software site is still failing, but, I gess we can use 0.11.2 as a workaround.
Thank you very much for your time.
Greetings,
Jose
Previous Topic:Diagram stores all pictogramLinks - simplify xml
Next Topic:SVG export fails with NPE
Current Time: Mon Jul 21 08:24:45 EDT 2025
Powered by FUDForum. Page generated in 0.07880 seconds
